High-performance cables [message #90751] |
Wed, 07 August 2019 15:10 |
musicluvr
Messages: 60 Registered: December 2018
Viscount |
Are any of the audio-video high-performance cables worth paying more for or is it a rip off and you should use the cables that came with your system or what you already have on hand? Can you really tell a difference between the two?
Re: High-performance cables [message #90752 is a reply to message #90751] |
Wed, 07 August 2019 15:36 |
Messages: 18686 Registered: January 2001
This is a subject that gets some pretty enthusiastic debates going in some audiophile circles. Some people think they find night-and-day differences between cables, but most people say they can't tell any difference.
I'll tell you what I think, coming from an engineering point of view.
Video cables are used at a frequency where inductance and capacitance matter, so the cable itself is important, especially longer lengths. Audio cables are used at a relatively low frequency, so inductance and capacitance are less relevant.
In general, I like to use a good pure-copper conductor of adequate size for the current required and an insulator that won't break down over time. Conductor size is generally only an issue in power and speaker output cables.
Beyond that, the connector and assembly is always important. A gold-plated connector will work better than a tin-plated connector, especially after it has been in place for a while. Tin oxidizes and forms resistance, reducing signal quality. Crimped conductor assembly is common, and it can be acceptable, but if the crimp bites into the conductor's copper and leaves it exposed, then the copper will oxidize and create resistance. It has to be sealed, soldered or welded for best quality.
Re: High-performance cables [message #90784 is a reply to message #90782] |
Wed, 14 August 2019 21:21 |
gofar99
Messages: 1906 Registered: May 2010 Location: Southern Arizona
Illuminati (5th Degree) |
Hi, I'm with Wayne. You can get quality cables at modest prices. I use a rule of thumb.... if an audio cable costs over $5 a foot (with connectors) it is probably a gimmick and overpriced. If a video cable is over about $10 a foot likewise. If a cable of either type is less than $.50 a foot it is probably going to cause problems. Usually the first thing to go are the terminations. I make all my audio cables and buy only reasonable video and RF ones. Thus far as picky as I am this has worked fine for many years.
Yes indeed you can get into real arguments on the subject...mostly IMO from people either make (and sell) or that just bought $1000+ wires.
