Home » xyzzy » Dungeon » I Hate Wire
I Hate Wire [message #89994] Wed, 03 April 2019 18:17 Go to next message
Hi, just beefing here...If it wasn't for wire I would never have a bad connection or loose cable or jack that came out. My system is admittedly more complex than most. I need the capability as I design gear. Everything needs to be "tested" in the main system to see if it does what I want. Reconfiguration takes place with what my spouse calls alarming regularity. Mad I see the nearly weekly alterations differently Smile Every time there is a change though it seems one or more devices is not doing its job. Hum, noise or no sound are the most common issues. It can nearly always can be traced to a cable or wire connection. Finding it can take some time and is a pain in the #$^^#. So that is why I hate wires. Anyone else have the same issue?
Re: I Hate Wire [message #90000 is a reply to message #89994] Thu, 04 April 2019 09:31 Go to previous messageGo to next message
Can't say wire as much as solder connections that have given me issues. Putting a tube amp kit together gave me a lesson in the merit's of good soldering. I had some cold solder's that gave me fit's tracing the culprit. If I ever get around to making another pair of speakers, I think I'll use those Neutrik speakeron connectors. They just seem to offer a more solid easy connection than typical binding posts.
Re: I Hate Wire [message #90015 is a reply to message #90000] Fri, 05 April 2019 18:40 Go to previous messageGo to next message
Laughing I'm laughing at this subject in solidarity with you!
I've done do so very many projects over the years. Most of my favorite things are things that I've made, and many of them are things that I've designed as well.
So my life is filled with equipment that represents hundreds of man-hours of design, development, prototyping, testing and refinement labor in addition to the costs of the parts.
I know you guys share the same experience.
Anyway, I find that I like to spend a good amount of time perfecting a design, and then making devices from it or having them made. I like to setup a system and just enjoy it, without tinkering with it. I like being done.
Re: I Hate Wire [message #90043 is a reply to message #90015] Sun, 07 April 2019 16:45 Go to previous message
Hi, What I really need is a new generation of components. You get them all together, throw them into a chassis, shake it three times, mention the magic word and zap....a new fully functional device. Rolling Eyes
Previous Topic: Modern Monetary Theory
Current Time: Thu Apr 25 23:49:55 CDT 2019
