Home » Sponsored » Pi Speakers » 2 Pi Towers build and flanking subs (2 Pi Towers build and flanking subs)
2 Pi Towers build and flanking subs [message #89849] Fri, 22 February 2019 11:08 Go to next message
tomgrote
Hi All
I am looking into building 2 Pi Towers. Plan on using 3/4 inch birch pw, do I need to adjust the dimensions or only the port size? Is it possible to place the speakers on the 13" side. Would like a little smaller face.
Also thinking of making flanking subs, but the 3 Pi subs are just too big for my space. How small of a sub can I use? What have other done?
Thanks
Re: 2 Pi Towers build and flanking subs [message #89850 is a reply to message #89849] Fri, 22 February 2019 14:11 Go to previous message
You can use either 5/8" or 3/4" panels. The plans show what size port to use for either case. Outside dimensions remain the same.
You can use any good quality subwoofer, but do remember that smaller subs necessarily sacrifice either extension or efficiency or a combination of the two.
Previous Topic: 4 Pi vs Competitors
Next Topic: 2 Pi completed
Current Time: Thu Apr 18 21:55:14 CDT 2024
