Home » Audio » Home Theater » Improving the home theater
Improving the home theater [message #89520] Wed, 09 January 2019 01:57 Go to next message
At times when I am at home, I almost feel like I should be getting more from the system. I actually feel like the reason for this is because I have used a combination of old and new speakers. Which is the best way to match such speakers?
Re: Improving the home theater [message #89524 is a reply to message #89520] Wed, 09 January 2019 03:45 Go to previous messageGo to next message
Having a combination of old and new speakers can be a tricky affair, and requires a good technique of matching them, so as to get the deserved sound experience. It may also be the right time to consider upgrading the subwoofer.
Re: Improving the home theater [message #89788 is a reply to message #89524] Mon, 11 February 2019 09:46 Go to previous messageGo to next message
Porter is currently offline  Porter
Have you considered getting a soundbar? Adding a soundbar to your home theater system is one of the easiest and most affordable things you can do to improve your audio experience in my opinion.
Re: Improving the home theater [message #89792 is a reply to message #89788] Mon, 11 February 2019 13:17 Go to previous messageGo to next message
Porter wrote on Mon, 11 February 2019 09:46
I stand corrected but from what I have heard, it is not advisable to have both a soundbar and home theater. The latter is often the cheaper and less bulky alternative.
Re: Improving the home theater [message #89808 is a reply to message #89792] Tue, 12 February 2019 14:07 Go to previous messageGo to next message
Mamoss, I know you weren't asking me specifically, but I believe you can hook up a passive soundbar to your home theater receiver and get great sound. Well, you can hook up an active soundbar to your home theater system too, but I believe the two amplifiers might interfere with each other. I'm not sure a soundbar is the best option. Home theater systems are better at creating an immersive experience. It also might be cheaper to just replace the speakers that aren't working well.
Re: Improving the home theater [message #89816 is a reply to message #89808] Wed, 13 February 2019 02:17 Go to previous message
Strum Drum wrote on Tue, 12 February 2019 14:07
Ooh yes and this makes sense because it is much easier and simpler to replace the old problematic speakers. I don't know much about the soundbar option but it looks like a tenable idea.
Previous Topic: Streaming or DVD.
Current Time: Wed Feb 20 12:41:00 CST 2019
