Best Amps for 3Pi [message #89452] |
Fri, 28 December 2018 14:50 |
Les Winter
Messages: 12 Registered: June 2009 Location: Northern New Jersey
Chancellor |
I have a pair of 3Pi's and am well pleased with them. I run a pair of flanking subs. So far I have run the 3's with a single ended all triode/no feed back amp (Tubelab SSE) and with an ultralinear el84 amp (stock Dynaco st35). The ultralinear amp is good for around 15 watts. The single ended is good for around 3.
I listen to opera and classical and not at ear shattering levels.
The single ended was a little too tubey for my tastes. The st35 is pretty good, but I'd like to know if more power would be better in this case.
Does anyone have experience with more powerful tube amps? I could build a KT88 amp that does 30 watts or so triode and 60 in ultra linear. It would be a lot of work. So before I start, anybody care to comment?
thanks.
Re: Best Amps for 3Pi [message #89454 is a reply to message #89452] |
Fri, 28 December 2018 18:03 |
Messages: 18678 Registered: January 2001
I won't recommend brands, but I will provide some (hopefully useful) feedback.
I've run all models on several amps including 2-10 watt SET, 10-30 watt ultra-linear tube amps, solid state chip amps from 25-100 watts and several-thousand watt class AB discrete transistors. I've also run a variety of digital amps from 25 watts (commercial) to several thousand watts (prosound).
All of them work well provided they are good-quality amps and they aren't pushed past their limits. When pushed past their limits, some amps are more graceful than others. Clipping is nasty on most solid state amps, less a problem on tube amps and especially SET amps.
I personally like amps with enough power. Single-ended amps are sweet, but I think people often push them past their limits. They don't get grungy when they start clipping, so people tend to get used to their sound. But they do start sounding a little bit strained or "heavy" sounding as they bump up against the rails and shave off the top of the waveform. So because of this, I tend to suggest a minimum of ten watts. I've run two watt SET amps, and they sound good and get plenty loud. But I'd rather have at least ten watts.
Once you move into the Class AB (and ultra-linear) tube amps, you have a lot of choices that offer enough power. In this world, I find the best amps sound a lot like SET amps and I've heard some really good Class AB and ultra-linear tube amps. Probably most of the high-end tube amps are in this category. But I find the lesser amps sound a little bit distorted all the time, and some of them make odd noises like squeaks and whistles. I think this is probably specific to certain brands and mismatched tubes though.
In the solid-state world, I find better amps sound very natural as long as they are not pushed into clipping. Once any solid-state amp starts to clip, it sounds harsh and "jagged." But lesser amps sound slightly distorted all the time.
I think I have a preconceived notion against digital amps because I tend to avoid them, except for light duty or things that I consider "secondary." I never use them for mains, but sometimes use them for surrounds and sometimes for subs. But they sound pretty good, so I think my bias is probably unfounded.
Above all, live with the amplifier for a while. One of the most important things is that the amplifier remains a constant for you for years and years. It should almost be "forgettable" in that it just amplifies the signal and other than that draws no attention to itself. It should be trouble-free and this isn't something you'll know until some time has passed.
Re: Best Amps for 3Pi [message #89469 is a reply to message #89452] |
Tue, 01 January 2019 10:03 |
johnnycamp5
Messages: 354 Registered: June 2015 Location: NJ
Grand Master |
I will also mention brands lol.
I have a couple of the ACA kits Barryso is talking about. I intend to try them as mono-blocks (15W each), but I haven't gotten around to building them yet..
I have built the Oddwatt Audio, S2 kt88 mono blocks, and they have sounded superb with my 4pi's over the long haul (about a year) without a single hiccup...
