Home » Audio » Home Theater » Wall Color
Wall Color [message #88994] Wed, 10 October 2018 19:00 Go to next message
Junior is currently offline  Junior
Most theaters are using dark colors on its walls. I don't know if it works well with home theater because dark colors look gloomy when we are not watching anything in the living room. What do you think?
Re: Wall Color [message #89376 is a reply to message #88994] Sun, 16 December 2018 14:01 Go to previous messageGo to next message
Porter is currently offline  Porter
When it comes to projectors, I think grayer tones are supposed to help the picture look its best unless you're planning to use a screen. If that doesn't appeal to you, what about adding a black border to frame out your white wall so that the viewing area is clear? It might be a good compromise. A lavender color might work as well.
Re: Wall Color [message #89388 is a reply to message #89376] Mon, 17 December 2018 08:39 Go to previous messageGo to next message
Lost the Remote is currently offline  Lost the Remote
I bought a kit with special paint for my wall and it turned out good, but if I had to do it again I'd install a retractable screen instead. In order for the video to look nice you need a perfectly smooth wall so there's a lot of work patching and sanding. And woe betide the person who touches the area with their dirty fingers after it's all said and done.
Re: Wall Color [message #89571 is a reply to message #89388] Sun, 13 January 2019 05:13 Go to previous message
Lost the Remote wrote on Mon, 17 December 2018 08:39
What color did you settle for eventually? I support the idea of a retractable screen as well. For the walls, neutral colors are usually recommended so that accurate colors are maintained on the screen. Mid-tones to dark shades of grey or brown give the best viewing experience. Though black is an obvious choice for most people, the room may eventually feel smaller.
Previous Topic: Is it better to sell or set up a secondary system
Next Topic: Problem with new OLED T.V.
Current Time: Tue Apr 23 10:44:58 CDT 2024
