Home » Sponsored » Pi Speakers » 7pi vs 8pi
7pi vs 8pi [message #66294] Thu, 24 February 2011 12:45 Go to next message
jgoodd8050 is currently offline  jgoodd8050
If I plan to build a top notch multi-sub bass system, is there any reason to go with a 7pi over the 8pi? I really want to use corner placement if possible.
I don't have all that much space to work with and 7pi sticks out in the room pretty far. I don't want to loose too much performance by going with the 8pi but it might be a better option.
Room size is 13x17 with a 7' ceiling. I plan to get a nice size screen between the mains too...
I'm using the studio 2pi's now.
Thanks for the advise.
Jeremy
Re: 7pi vs 8pi [message #66297 is a reply to message #66294] Thu, 24 February 2011 15:25 Go to previous messageGo to next message
The eight π is an entry-level cornerhorn. As an aside, it is kind of a hybrid, in that it doesn't necessarily need to be placed in corners but that's where it works best. But the point is that the seven π cornerhorn is a better speaker, particularly when outfitted with all the upgrade options.
Re: 7pi vs 8pi [message #88991 is a reply to message #66294] Wed, 10 October 2018 16:35 Go to previous messageGo to next message
Bringing up this old thread to ask a somewhat related question.
In consideration of saving space in the room,
using a forward firing 2226h bass bin under the 7pi (or should I say, under a pi mid horn and tweeter horn) it looks like one could save approximately 8" of depth............ but.........
Has anyone tried this with their corner horns?-
1- What does the bass bin of the 7pi bring, that a forward firing 2226 would not?
2- Is there acoustic loading on the bass driver of the 7pi...like the mid horn and cd horn above it?
3- If so, is there an increase in spl and a decrease in excursion/distortion as a result, like many other horn loaded designs?
4- Besides some (if any) directivity loss, how dramatic do you suppose this difference (direct radiator vs. rear firing (horn) would be?
If the answer to question #4 is "much less dynamic" (punch and drama), then I would consider the idea a non starter.
Re: 7pi vs 8pi [message #88998 is a reply to message #88991] Wed, 10 October 2018 21:32 Go to previous message
Facing the woofer towards the corner allows it to be acoustically close to the corner. This allows the walls to act as a source boundary - something like vertical ground planes - rather than as reflectors.
The goal is to make the sound source(s) act the same as if they were mounted flush into the wall, or rather into the corner.
Bringing the woofer out to the front of the cabinet makes it far enough away from the walls that they begin to act as reflectors. The wavefront launch is perturbed because the woofer is no longer acoustically close. This causes a self-interference notch in the upper-midbass to lower-midrange.
As an aside, this is the condition that flanking subs are designed to correct. That's why I often suggest that mains with traditional forward-facing midwoofers be flanked by "helper woofers" that overlap the mains in the upper-midbass. The midwoofer and the flanking sub form a two-element array which smoothes the self-interference notch from the wall behind the speakers and other nearby boundaries.
Previous Topic: 3Pi & 3Pi Sub Plans request
Next Topic: Sound for small gym
Current Time: Sat Apr 20 02:09:00 CDT 2024
