Home » Audio » Movies & Music » Converting home cine to digital - how?
Converting home cine to digital - how? [message #88340] Thu, 05 July 2018 10:41 Go to next message
JazzHog is currently offline  JazzHog
I have had the good fortune to inherit the family home cine films from the 1960's which have on them a lot of family history. The question is, how do I go about converting these to a digital format that can then be distributed amongst the relatives?
I know that some commercial services are available, but I am also wondering about having a go myself.
Any advice gratefully received!
Re: Converting home cine to digital - how? [message #88341 is a reply to message #88340] Thu, 05 July 2018 11:03 Go to previous messageGo to next message
Rusty is currently online  Rusty
This one calls for google. Probably very tedious to do diy but, here's one for 35 mm slide's that may be applicable to film.
http://www.instructables.com/id/35mm-Slide-Converter-with-Cellphone/
Or, a converter, which is probably still tedious and give varying results in quality. https://www.amazon.com/Wolverine-Mighty-20MP-Digital-Converter/dp/B00O46B7TY
Or just have it done commercially if it's a one shot conversion of film to digital. I know I'd do it that way, especially if it was just one reel of film.
Re: Converting home cine to digital - how? [message #89128 is a reply to message #88340] Fri, 09 November 2018 03:53 Go to previous messageGo to next message
Groot is currently offline  Groot
I would also go for a commercial copy of this one. I don't think there is an application that automatically converts an old film into digital. We also need to consider the type of recording the film was recorded in.
Re: Converting home cine to digital - how? [message #89205 is a reply to message #89128] Wed, 14 November 2018 13:58 Go to previous message
The problem with hiring someone to do it is that it's very expensive if you have a lot to convert. We paid hundreds of dollars to have my grandparents' old 8mm films converted. I It might be worth trying on your own to save money. Just be sure to practice on the one you care the least about in case it gets ruined. Good luck! https://www.consumerreports.org/audio-video/how-to-convert-film-and-vhs-to-digital/
Previous Topic: Rock and Roll Hall of Fame
Next Topic: Movie Software
Current Time: Fri Apr 26 07:01:44 CDT 2024
