Home » Sponsored » Pi Speakers » 7 PI digital to passive (crossover)
7 PI digital to passive [message #87511] Fri, 23 March 2018 13:26 Go to next message
mk15 is currently offline  mk15
Hi Wayne,
I have been enjoying my 7 PIs for quite some time now. Used tri-way class D amps with miniDSP.
I always wanted to get a taste of class A amplification and going to build one. My plan to change to bi-amping with a single Class A amp handling mids+highs. Hence a switch to passive crossover.
Could you please send me a schematics for 3-way 7 PI.
I built a midhorn a little larger than on your plans so its back almost touches the corner walls.
Also JBL2226 in my system are 16 ohms, should I use a smaller inductor value ?
And what wire gauge/DCR do you use in your crossover inductors ?
Thanks in advance,
Michael
Re: 7 PI digital to passive [message #87528 is a reply to message #87511] Sat, 24 March 2018 11:33 Go to previous messageGo to next message
You've got mail!
The minimum wire size you should use on coils is 20 gauge, but I suggest going bigger than that. We use 18 gauge air-core coils everywhere except the woofer, which has a 16 gauge laminated iron-core coil. An upgrade to 15 gauge is available.
I have a requirement of DCR less than 25% of the load, but I prefer to keep DCR under 10%, e.g. 0.8Ω for 8Ω drivers. In most locations, I achieve this with the 18 gauge parts but in some cases, I'm using parts that exceed the goal by a wide margin. For example, the coil in the woofer circuit of the constant-directivity cornerhorns has DCR of 0.25Ω.
The three π and four π loudspeaker models use a 1.5mH coil in series with a 0.5mH coil in the third-order midwoofer crossover circuit. The 18 gauge 1.5mH air-core coil has DCR of 0.65Ω in series with the 0.5mH coil which has DCR of 0.35Ω. So total resistance is a little over my goal of 10%. The 15 gauge upgraded inductors are 0.35Ω and 0.2Ω, respectively, which keeps DCR well under the 10% goal.
The six π and seven π constant-directivity cornerhorns use a 1.0mH coil in series with the 0.5mH coil in the midhorn circuit. Of course, the midhorn is padded so DCR isn't as critical in this part of the circuit. But the 18 gauge 1.0mH air-core coil has DCR of 0.45Ω and the 15 gauge part has DCR of 0.3Ω.
And yes, when using a 2226J, go with a 12mH coil in the woofer circuit. As I said above, don't skimp on the wire gauge.
Re: 7 PI digital to passive [message #87529 is a reply to message #87511] Sat, 24 March 2018 14:27 Go to previous messageGo to next message
Thanks very much Wayne.
So in your opinion it is not detrimental to use laminated iron-core coils for the woofer ?
What do you think about possibility of active filter for the woofer ?
Re: 7 PI digital to passive [message #87532 is a reply to message #87529] Sun, 25 March 2018 11:08 Go to previous message
The woofer circuit in this design isn't critical. It's low-passed very gradually, with plenty of overlap with the midhorn to smooth vertical modes. The only thing that's required of the woofer circuit is to attenuate the very high frequencies.
As for the coil, as long as it doesn't become saturated, laminated cores are fine. Air core coils prevent this possibility but a good iron core like the Erse Super-Q works very well and sounds great.
It doesn't even come close to saturation at the maximum power level. At 600 watts, there's 8 amps flowing through the coil and it doesn't saturate until 20 amps. So laminated iron core coils are just like output transformers - use them within their limits and they're fine.
Previous Topic: Pi4 Erse Coils for sale
Next Topic: Cabinet Doors, 3Pi changes and Plan Request
Current Time: Mon Apr 29 06:31:08 CDT 2024
