Home » Audio » Room Acoustics » Room size effect
Room size effect [message #84927] Sun, 09 April 2017 15:46 Go to next message
Ssal is currently offline  Ssal
Quick question from a totally tech challenged person. Does the size of the room affect the quality of sound, and if so, which is better a small room or a large one?
Re: Room size effect [message #84930 is a reply to message #84927] Sun, 09 April 2017 16:01 Go to previous messageGo to next message
The size matters inasmuch as that determines what you need to put in the room in order to achieve the acoustical quality you're looking for. Or rather, listening for I guess.
Re: Room size effect [message #84956 is a reply to message #84927] Mon, 10 April 2017 08:55 Go to previous message
Larger. Room modes are stronger in smaller rooms.
But by saying "larger," I mean really large, like several thousand square feet.
Small and medium size rooms (like one would expect in a home) are improved with damping material. Framed drywall helps damp modes, because the panels vibrate and absorb energy. Carpeting, drapes and furniture also damp the sound.
Previous Topic: Room layout
Next Topic: How to find the acoustic sweet spot in a room
Current Time: Thu Mar 28 14:38:25 CDT 2024
