Re: OTL amps [message #8270 is a reply to message #8268] |
Wed, 16 June 2004 13:01 |
rick
Messages: 53 Registered: May 2009
Baron |
Hey Wayne: I have OTL mono amps. They're from Transcendent Sound right where I live in K.C. Mo. They are the T-16 mono kits developed by Bruce Rozenblit. Each amp can put out 40 watts of very high quality sound. They can drive a 4 ohm load, which they did quite well when I first got them. But eventually and intentionally I mated them with your Theater 4 Pi's, and I got to tell you the resulting offspring between these two designs are pure joy. Bass is dynamite, mid's & highs very realistic. Also I'd built Rozenblit's Grounded Grid preamp from his book Audio Reality and this as much as everything else makes me happy I persued this audio mania. And you know how insane audio can be. I built it me self and saved a heap. The OTL's downside is by design, HEAT! But Rozenblit's design philosophy is geared toward that issue, and reliability. So even with 16 russian 6c19pi tubes bristling on top each amp, they're not space heaters in the winter and weber grills in the summer. Plus I've never had a lick of trouble except one output tube that the heater element went bad. Luckily I found also a reliable and inexpensive source of tubes for this amp on e-bay, called KW tubes in Lithuania. The thought of re-tubing these amps eventually with 32 tubes was daunting to think of. But at a little over 3 bucks apiece, thats real good, about 1/3 what I'd searched elsewhere.
Re: OTL amps [message #8271 is a reply to message #8270] |
Wed, 16 June 2004 14:17 |
Messages: 18677 Registered: January 2001
Hi Rick, Wow! Thanks for your input. I've heard lots of good things about Rozenblit's amps. So one of these days soon, I'll have to give the Transcendent Sound amps a try. Wayne
Re: OTL amps [message #8438 is a reply to message #8270] |
Mon, 06 September 2004 19:12 |
HaknHendrix
Messages: 25 Registered: May 2009
Chancellor |
Rick: Glad to hear you like the GG and the T16 mated with the Theater 4 Pi's. Hakn Jr and I built a Forplay that sounds real nice - for variety, I decided to build a GG - I have heard great reviews of the pre-amp. I intended to scratch build it - trusting that my Foreplay experience is sufficient. Once done, I'm contemplating the T-16 Kit as well. Do you that their is sufficient ommph to drive the 4-Pi's, should be as they are very efficient! Any sage advice concerning other DIY options before I dive headlong into this audio extravaganza? Thanks Hakn Sr.
