Home » Audio » Home Theater » Receiver/Amp/CD player
Receiver/Amp/CD player [message #82459] Sat, 23 April 2016 22:09 Go to next message
The Noise is currently offline  The Noise
Can anyone recommend a good combination set-up that includes all three of these? I am looking to upgrade a system in a small room.
Any help would be appreciated.
Re: Receiver/Amp/CD player [message #82631 is a reply to message #82459] Tue, 17 May 2016 02:35 Go to previous messageGo to next message
minora is currently offline  minora
I found several receiver/player combo. Here they are:
http://nadelectronics.com/products/hifi-receivers/C-715-Compact-Music-Systems
http://usa.yamaha.com/products/audio-visual/hifi-systems/crx-330_black__u/?mode=model
http://usa.yamaha.com/products/audio-visual/hifi-systems/drx-730_black/?mode=model
I've heard Yamaha usually has good quality, but the website says the product is discontinued so maybe you can check the other mini system products listed. I hope it helps.
Re: Receiver/Amp/CD player [message #82849 is a reply to message #82631] Sat, 18 June 2016 02:51 Go to previous message
dreamer13 is currently offline  dreamer13
Thank you for the info. This is a good solution because my room is also small but I want to have a good overall audio system. My friends said that at least a good amp and player will be enough if the room is not too big.
Previous Topic: The best Home Theater brand
Next Topic: 4k HDMI cables
Current Time: Sun May 05 01:27:45 CDT 2024
