3 Pi build in Italy... [message #81992] |
Wed, 10 February 2016 07:53 |
porfido1974
Messages: 1 Registered: February 2016
Esquire |
Hi,
First of all, sorry for my bad english...
I opened this thread to tell a REALLY BIG "thank you very much!!!" to Wayne!
These are the second couple of Pi Speakers I built and I couldn't be more satisfied and happy about them!
Of course my skills are far from good and the result is also...
I used 1" mdf for front and rear and added a brace...
Painted the inside with many coats of waterproofing compound...
Built separate filters...
Made the horn recesses following this very good tutorial:
http://www.exquisiteaudio.com/baffle.html
Iron washers and putty for attaching the grills by magnets...
Reflex ducts made by some mdf rings glued together...
Primer...
Varnex paint by roller...
Rubber feet...
Drivers mounted...
Grills attached...
Ok and "How do they sound?"...
So good I keep smiling and smiling listening to them...
THANK YOU VERY MUCH AGAIN, WAYNE!!!!
Attachment: img_2810.jpg
(Size: 207.65KB, Downloaded 2111 times)
Attachment: img_2813.jpg
(Size: 205.59KB, Downloaded 2059 times)
Attachment: img_2814.jpg
(Size: 115.58KB, Downloaded 2058 times)
Attachment: img_2815.jpg
(Size: 100.40KB, Downloaded 2108 times)
Attachment: img_2816.jpg
(Size: 148.91KB, Downloaded 2075 times)
Attachment: img_2817.jpg
(Size: 176.75KB, Downloaded 2049 times)
Attachment: img_2910.jpg
(Size: 187.25KB, Downloaded 2044 times)
Attachment: img_2911.jpg
(Size: 87.70KB, Downloaded 2038 times)
Attachment: img_4010.jpg
(Size: 91.85KB, Downloaded 2036 times)
Attachment: img_4110.jpg
(Size: 197.13KB, Downloaded 2034 times)
Attachment: img_4111.jpg
(Size: 147.22KB, Downloaded 2006 times)
Attachment: img_4113.jpg
(Size: 185.30KB, Downloaded 2056 times)
Attachment: img_4116.jpg
(Size: 183.30KB, Downloaded 2049 times)
Attachment: img_4211.jpg
(Size: 143.13KB, Downloaded 2052 times)
Attachment: img_4212.jpg
(Size: 175.69KB, Downloaded 2043 times)
