Home » Audio » Pro Sound » Midrange Dispersion (Closed Box or Horn?)
Midrange Dispersion [message #81568] Mon, 07 September 2015 20:37 Go to next message
B1189BW is currently offline  B1189BW
All:
I am adding a 10" midrange cone speaker to an existing system.
I have a pair of well made JBL two way install cabinets that I have put JBL 2226s and 2450 drivers on 2382A horns in (120 X 40). I also have the option of a pair of JBL 2380As (90 X 40). I crossover at 1200Hz.
I recently purchased a pair of JBL 2012 10" midrange speakers that in intend to place on top of the two-way cabinets and crossover at 300 Hz. Thus 300 Hz and still 1200 HZ.
My question is: should the midrange driver be placed in a closed box to more match the dispersion of the low end ported cabinets or on horns to more match the high end horns?
Thank you for any thoughts,
Bill
Re: Midrange Dispersion [message #81569 is a reply to message #81568] Tue, 08 September 2015 16:37 Go to previous messageGo to next message
You will always benefit from well-made horns provided you have the room and you can provide an appropriate crossover, which accounts for path length differences. Horns provide improved efficiency, lower distortion and more directivity control.
Re: Midrange Dispersion [message #81585 is a reply to message #81568] Mon, 21 September 2015 22:41 Go to previous message
Sorry for the delay in answering but . . . Thank you for your answer. I will as a follow up question on your forum.
Previous Topic: Elixir strings or...?
Next Topic: Starter drum set for daughter
Current Time: Wed Apr 24 13:06:23 CDT 2024
