Home » Sponsored » Pi Speakers » Four Pi Waveguide Placement
Four Pi Waveguide Placement [message #81112] Fri, 13 February 2015 17:53 Go to next message
timhowell01 is currently offline  timhowell01
I'm just about to make the cutouts on my Four Pi baffles for the waveguides and ports. However, the dimensions in the Four Pi plans don't quite seem to match the dimensions of the actual waveguide. From the plans it looks like the edge of the waveguide should be 1.75 inch from the side of the box, and that the waveguide is 10.5 inches wide, but my waveguide is actually 11 5/8 inches wide. From some quick math it looks like the center of the waveguide is supposed to be 7 inches from the side, which makes the edge of the waveguide 1.1875 inch from the edge of the cabinet.
Am I missing something here?
Thanks in advance, Smile
--TWH
Re: Four Pi Waveguide Placement [message #81126 is a reply to message #81112] Sun, 15 February 2015 11:36 Go to previous message
The hole shown on the plans is for the baffle cutout, and doesn't show overall H290C dimensions. The waveguide is set into that hole from the front.
Previous Topic: Ordered new waveguide H290C
Next Topic: Measurement Microphones
Current Time: Sat Apr 27 22:39:54 CDT 2024
