Home » Sponsored » Pi Speakers » Help me troubleshoot freaky cabinet-tuning issue? (2225Hs in 3ft3 - one cab rolls off at 110Hz, the other at 60Hz)
Help me troubleshoot freaky cabinet-tuning issue? [message #79934] Wed, 07 May 2014 20:16 Go to next message
Fritz Bogott is currently offline  Fritz Bogott
I have a pair of JBL 2225Hs in 3ft3 3/4" MDF cabs tuned to 40Hz.
Using Room EQ Wizard as a real-time analyzer, I can see that one cabinet drops off sharply at 110Hz, the other at 60Hz. (I'm not moving the mic; it's sitting on a tripod about ten feet back and midway between the two cabs.) There shouldn't be a (major) directivity issue with mid-woofers, should there?
Swapping the drivers (oof, heavy) has no effect on this-- the 110Hz rolloff follows the cab not the driver.
In order to reduce the number of variables, I yanked the port tubes from both cabs. Weirdly, the rolloff points of both cabs did not change. (D'oh!) Still 60Hz and 110Hz. (Huh? I don't see how this can be possible?)
What's left to look at? As far as I can see, the cabs have identical cross-bracing and identical amounts and placement of R11 insulation. I sealed all the joints in both with silicone...
Ever run into anything like this before? Seems completely impossible / unbelievable to me. What should I look at next?
Thanks,
-Fritz
Re: Help me troubleshoot freaky cabinet-tuning issue? [message #79935 is a reply to message #79934] Wed, 07 May 2014 20:32 Go to previous messageGo to next message
If the cabinets were plywood, I would suspect a void. I think there is a glue up error. Check all of your bracing. Make sure there aren't any gaps in the structure.
Solved: Gnarly room modes. [message #79937 is a reply to message #79935] Wed, 07 May 2014 20:58 Go to previous messageGo to next message
D'oh. It was a mic-placement / room modes issue. Now I have the room modes to deal with, but at least I know it's not the cabs.
Re: Help me troubleshoot freaky cabinet-tuning issue? [message #79938 is a reply to message #79935] Wed, 07 May 2014 21:00 Go to previous messageGo to next message
Thanks, Steve. It turns out I was controlling for the wrong variables entirely. The rolloff had to do with the placement of the speakers in the room and the placement of the mic relative to the speakers.
Re: Help me troubleshoot freaky cabinet-tuning issue? [message #79946 is a reply to message #79934] Sun, 11 May 2014 12:03 Go to previous message
Hi Fritz,
For some reason, I thought you had eliminated speaker positioning as a problem area. Rooms can cause havoc. I'm happy you've discovered the problem. Best of luck & be patient. It can take a while to get it right.
Steve
Previous Topic: 7 Pi in NorCal?
Next Topic: Speaker Building
Current Time: Sat May 11 14:59:44 CDT 2024
