Home » Sponsored » Pi Speakers » H290C and JBL LE14H-3
H290C and JBL LE14H-3 [message #79347] Fri, 07 February 2014 13:12 Go to next message
BHamm is currently offline  BHamm
Hello all. My first post here.
I am hoping to finish an old project. I have the JBL LE14H-3 that I want to pair with the H290C and DE250 driver. I will use a modified econowave x-over which lowers the crossover frequency to 900Hz for the LE14. My question is will the H290C play down that low without distortion or break-up? I have not bought waveguides or CDs yet due to my apprehension. Any thoughts?
BHamm
Re: H290C and JBL LE14H-3 [message #79358 is a reply to message #79347] Sat, 08 February 2014 16:04 Go to previous messageGo to next message
Hard to find specs on the LE14 away from it's Array, or as a sub-woofer, but the rubber surround perhaps means a lot of xmax and a lower efficiency than you might want to pair with a compression driver.
JBL crosses it at 300Hz as a sub, the DE-250 Fs is 1,000 Hz. You must have information I can't find to want to do this?
Re: H290C and JBL LE14H-3 [message #79359 is a reply to message #79347] Sat, 08 February 2014 16:07 Go to previous messageGo to next message
I may have answered my own question. I found this graph from another website:
Looks like it doesn't start tapering off until 850 Hz or so.
It was a toss up between the H290C or SEOS-15.
index.php?t=getfile&id=1411&private=0
  • Attachment: image.jpg
    (Size: 298.97KB, Downloaded 3358 times)
Re: H290C and JBL LE14H-3 [message #79360 is a reply to message #79347] Sat, 08 February 2014 16:38 Go to previous messageGo to next message
index.php?t=getfile&id=1412&private=0Here is a freq response I found for the JBL.
Looks like it will play high enough for the 2-way speaker I hope to build.
    (Size: 232.61KB, Downloaded 3343 times)
Re: H290C and JBL LE14H-3 [message #79476 is a reply to message #79360] Mon, 17 February 2014 09:06 Go to previous messageGo to next message
maxserg is currently offline  maxserg
The freq resp in on axis for the LE14. No shure it would go higher than 500/800Hz, you would need a horn that goes lower. The dispersions need to be almost the same for the 2 components at xover point.
Re: H290C and JBL LE14H-3 [message #79477 is a reply to message #79476] Mon, 17 February 2014 10:43 Go to previous message
Thank you for the reply.
I guess I really won't know for sure until I have the equipment to accurately measure them. Until then I am shooting in the dark.
I am waiting on some parts to finish them, so I will have an idea soon.
If I can't make the JBLs play in a 2-way arrangement, I will sell off the drivers and buy some that will.
Many thanks,
BHamm
Previous Topic: Speaker stuffing
Next Topic: Restoring a 1951 Philco 5W mono console... Thinking a 7 Pi! (Have a few questions)
Current Time: Wed May 01 22:05:04 CDT 2024
