Re: What Was Your First Stereo? [message #75267 is a reply to message #75258] |
Tue, 15 January 2013 21:58 |
gofar99
Messages: 1907 Registered: May 2010 Location: Southern Arizona
Illuminati (5th Degree) |
Hi, Not so high class... a 10 watt solid state amp from Lafayette Electronics (long gone into the sunset now) a BSR record changer and a pair of Lafayette Minuette speakers. Complete with a Sonotone stereo ceramic cartridge with a saphire needle (really high tech then). All the stuff is long gone but it was cool back then. Eventually a 7 inch reel to reel monaural tape recorder joined the fray.
Now I have more stuff than I can count. I should open a stereo store... 4 turntables, at least 6 preamps, 3 stereo receivers, 2 HT multichannel receivers, unknown number of amps (6 tube mono blocks and 3 stereo tube amps in the living room alone - probably about 6-9 more in the shed). No idea how many pairs of speakers are here now (best guess is about 20 pairs, many name brand vintage ones, Altec Lansing, Klipsch, etc, 6 powered subs of assorted sizes, a pair of huge free air sub woofers. Small wonder I had to get a "barn" style shed with loft to store much of it. I guess this is what happens when you become your own boss and design electronics for the fun of it. Being half owner in a company that sells kits of a number of the things designed could be part of it as well. No telling how many prototypes are on the premises. Sorry everyone... the topic got me carried away.
Re: What Was Your First Stereo? [message #75729 is a reply to message #75188] |
Wed, 06 March 2013 16:33 |
FloydV
Messages: 124 Registered: November 2011 Location: Boise, ID
Master |
I think my first experience (you have to be really old to tell this story)was right at the introduction of stereo. We had a mono record player with amp and speaker all in one.
I started looking at the (crystal) cartridge and noticed it had four pins, but only two were being used. I hooked the other two to a radio that had a phono input on the back. The sound was horribly mismatched, but it was stereo.
After that I assembled an EICO tube pre/power amp from a kit with 14 watts per channel. All point to point wiring and discrete components. I bought some Jensen speakers that weren't all that good and a turntable with a ceramic cartridge.
After that I went to a magnetic cartridge and Dual turntable. If memory serves, that turntable had an arm you zero, and then you dialed in the force in fractions of a gram that was applied by a spring. One of their ads showed the turntable playing at a 45 degree angle with the arm playing up hill.
After that it was a regular progression from tubes to transistors, more power, better speakers, more expensive turntables and cartridges.
Floyd
Re: What Was Your First Stereo? [message #75736 is a reply to message #75730] |
Wed, 06 March 2013 17:40 |
FloydV
Master |
They were a big improvement over anything previously available to the consumer. I don't remember them being that expensive either.
I found the whole learning experience exciting. I had friends who would bring records over because they wanted to hear them on a system that sounded good. It really wasn't that good, but this was the time of real transition in music and equipment and most people were just becoming aware.
Floyd
