Making printed circuit boards [message #74987] |
Mon, 17 December 2012 18:05 |
FloydV
Messages: 124 Registered: November 2011 Location: Boise, ID
Master |
I would like to make some printed circuit boards. The only PCBs I have done were a long time ago where you used a pen to trace the circut over specially coated copper, then immersed the board in a solution to remove all the copper except where the lines were drawn.
Can someone bring me up to speed on newer processes. I would especially like to design the circuits in a drawing program and somehow get that drawing onto the board.
Thanks,
Floyd
Re: Making printed circuit boards [message #74988 is a reply to message #74987] |
Mon, 17 December 2012 18:59 |
Messages: 18695 Registered: January 2001
That etch resist technique doesn't work too well, does it?
The "newer processes" are actually no different than the older processes when it comes to fiberglass PCB manufacturing. They have offered various products for years, from single-sided and double-sided to multiple layers, with or without a solder mask and/or silkscreen. The solder mask is the green coating that prevents the solder from sticking where it isn't wanted, mostly done for wave soldering but usually there on high-quality boards even if volume is low (and therefore will be hand-assembled). The silkscreen is there to help identify component locations. It's usually done in white, mostly part identification numbers and sometimes outlines of where some parts go.
What is newer is the CAD software used to deliver the artwork to the board house. It used to be done photographically, and your layout engineer would "lay tape". Literally. They used strips of colored translucent tape fastened to large clear sheets of plastic, one per layer. They often used different colored tape so when each layer was laid on top of each other, you could see the layers easily by color coding. But this was just for convenience while developing and checking the layout, because the final product of the layout engineer is a photographic positive done in black on clear at scale for each layer requested.
Now days, this is usually done electronically by sending a CAD model of the layout in a standard Gerber format. You can design the board using OrCAD or something similar, and then send the Gerber file to the board house for quotations. They usually have an inexpensive prototype trial run these days (which they didn't have in decades past), so you ask for a relatively small number. If you approve the quote, they'll use the Gerber file to make the boards and send 'em to you. The inexpensive trial runs are nice, because back in the day, you didn't have that luxury so you better get it right first time. Otherwise, you had "Engineering Change Orders" (ECOs) that essentially meant you cut a trace and if it needs to be rerouted, you soldered a small wire-wrap wire onto the board as a replacement conductor. It could be a bear to find a problem in a first-run too, especially in complex designs.
Re: Making printed circuit boards [message #74997 is a reply to message #74988] |
Mon, 17 December 2012 22:32 |
FloydV
Master |
Thanks Wayne. By inexpensive trial run, how much is inexpensive?
To start with, I wouldn't make anything more complicated than say a crossover board. Or maybe a radio wave door bell to remote bright light in the theater room.
Is the old pen and mask still available to play with?
Floyd
Re: Making printed circuit boards [message #75044 is a reply to message #74999] |
Mon, 24 December 2012 17:57 |
FloydV
Master |
I think I just listed your link in another post. I know I can get chemicals from someone like Scientific Products or Sergeant-Welch, but they probably won't sell less than 500 grams. Do you have any favorite supplier?
Floyd
Re: Making printed circuit boards [message #75048 is a reply to message #75044] |
Tue, 25 December 2012 09:15 |
gofar99
Messages: 1909 Registered: May 2010 Location: Southern Arizona
Illuminati (5th Degree) |
FYI, we use Express PCB to do the boards for our products (Oddwatt Audio). It works fine and the board maker will do the translation to Gerber for us. They generally are not up for doing much under 25 pcbs at a time though.
