Home » Sponsored » Pi Speakers » 4Pi measurements
Re: 4Pi measurements [message #74363 is a reply to message #74359] Sat, 03 November 2012 17:55 Go to previous messageGo to next message
Glad the problem was an easy fixer!
Re: 4Pi measurements [message #74364 is a reply to message #74272] Sat, 03 November 2012 19:27 Go to previous messageGo to next message
thatsnasty is currently offline  thatsnasty
zheka wrote on Fri, 26 October 2012 21:51
I wish mine were as well built as BigMouthinDc's Wink I probably made all the usual rookie mistakes and than came up with some more. On the bright side, I will keep the speakers behind the screen so the looks are not all that important.
I did not have a chance to listen to them in any meaningful way. And, for reasons beyond my control, I won't be able to for at least another week. the suspense is killing me but there is nothing i can do...
BTW, I'd gladly help you with measurements if you'd like, as long as you keep in mind the limitations of my gear and expertise.
I appreciate it! I'll definitely be posting when I get them finished. I'm off tomorrow so maybe they'll be done then.
Glad it was just the Zoebel.... I was debating soldering it to the X-over board when I attached them but didn't bother because the clip leads fit really snug.
Re: 4Pi measurements [message #74366 is a reply to message #74358] Sat, 03 November 2012 20:50 Go to previous messageGo to next message
zheka wrote on Sat, 03 November 2012 15:26
I finally had a chance to open the speaker with unhealthy boost in the crossover region - the zobel was disconnected! what a relief.
I thought that was probably the cause. Glad you took the time to measure the speakers - It sure helped you nail it down!
Re: 4Pi measurements [message #74370 is a reply to message #74366] Sun, 04 November 2012 00:19 Go to previous messageGo to next message
Wayne,
Tonight is the first time I am using your speakers in any meaningful way. I cannot be happier about what I am hearing.
Thank you very much.
index.php?t=getfile&id=1253&private=0
Re: 4Pi measurements [message #74371 is a reply to message #74370] Sun, 04 November 2012 01:10 Go to previous messageGo to next message
Очень хорошо!
Я с большим удовлетворением.
Re: 4Pi measurements [message #74380 is a reply to message #74239] Sun, 04 November 2012 23:07 Go to previous messageGo to next message
index.php?t=getfile&id=911&private=0
Cellphones are not good cameras, lol.
More to come Smile
I'm Thinking about picking up an Omnimic soon.
Re: 4Pi measurements [message #74381 is a reply to message #74380] Mon, 05 November 2012 06:31 Go to previous message
Thumbs Up
Previous Topic: 3 Pi Plans
Next Topic: B&C DE250 question
Current Time: Mon May 06 21:01:33 CDT 2024
