Home » Sponsored » Pi Speakers » auralex wedges in place of R13
auralex wedges in place of R13 [message #73093] Thu, 21 June 2012 20:34 Go to next message
I have some leftover auralex wedges that I am considering to use instead of R13 to line up the enclosures.
Is there any reason to believe it will not be as effective as R13 for the job?
Re: auralex wedges in place of R13 [message #73094 is a reply to message #73093] Thu, 21 June 2012 21:57 Go to previous messageGo to next message
No, don't use it. Use the R13 as described in the plans - lining the side, back and top or bottom (depending on model) and one sheet spanning the cross-section.
Re: auralex wedges in place of R13 [message #73103 is a reply to message #73094] Fri, 22 June 2012 15:18 Go to previous messageGo to next message
Thank you.
Are 4pi crossovers built based on the specific drivers combinations or the drivers are sufficiently similar so that the same crossovers can be used?
Re: auralex wedges in place of R13 [message #73104 is a reply to message #73103] Fri, 22 June 2012 15:30 Go to previous messageGo to next message
We need to know the drivers chosen. Please tell us in the notes section when you place your order. If you forget, we will email you and ask.
Re: auralex wedges in place of R13 [message #73105 is a reply to message #73104] Fri, 22 June 2012 15:33 Go to previous messageGo to next message
makes perfect sense. thank you
Re: auralex wedges in place of R13 [message #73150 is a reply to message #73093] Thu, 28 June 2012 05:32 Go to previous messageGo to next message
thatsnasty is currently offline  thatsnasty
Wayne is there anything else that will work in place of R13?
I'm in Canada and it's impossible to find that stuff here... I've looked everywhere. I can get R14 or similar insulation types around 3-3 1/2" thickness, but that's about it.
Re: auralex wedges in place of R13 [message #73154 is a reply to message #73150] Thu, 28 June 2012 08:06 Go to previous message
R14 is fine. Just don't use any of those alternate materials. Fiberglass works best.
Previous Topic: Wayne, question about Vifa DX-25
Next Topic: First Post, 2 Pi, Ear Discomfort
Current Time: Sat May 04 09:38:22 CDT 2024
