Wayne Parham Messages: 18680 Registered: January 2001
That looks like it would work just fine. If you get a set of those, report back how they work for you.
I use wood stands with the top plate pretty close in size to the cabinet size. The back edge has a lip that cradles the speaker. I also use rubber underneath to grip the speaker. Between the rear lip and the rubber underneath, the speaker is planted nicely and doesn't move.
