Home » Sponsored » Pi Speakers » B&C DE250/H290 supplement.
B&C DE250/H290 supplement. [message #70368] Sat, 03 December 2011 07:44 Go to next message
Roland Gama is currently offline  Roland Gama
Hello Wayne,
Want your thoughts on this:
I have built a pair of push-pull design sealed 60 litre boxes with the lab12's doing the sub-work. So that is 4 lab 12's in all.
I use this set up with the Bose 901's (long story) through the DEQ2496 and the DCX2496.
I also use REW and find that the 901's inherently can't reproduce the highs after about
17khz.
That is the reason I thought of adding the DE250 horn on top of the 901's. to give it some sparkle.
If you are positive on this then I would be very happy to have any plans for a wood horn
for the DE250.
Awaiting your reply,
Roland.
Re: B&C DE250/H290 supplement. [message #70369 is a reply to message #70368] Sat, 03 December 2011 09:09 Go to previous messageGo to next message
A Bose 901 creates a sound field that is 90% reflected. A horn creates sound that is 90% direct. They are two different approaches and I wouldn't combine them.
In my opinion, directional sound is best for mains and reverberent sound is best for surrounds. So I'd use some horn/waveguide speakers for your mains and repurpose your 901 speakers as surrounds.
But that's answering a question you didn't ask. To answer the one you did:
If I wanted to add some sparkle to 901, I'd probably add dome tweeters on each side.
Re: B&C DE250/H290 supplement. [message #70387 is a reply to message #70369] Mon, 05 December 2011 08:11 Go to previous messageGo to next message
Hello Wayne
Thanks for the reply.
For the sake enlightenment- What would be the expected outcome if I place the 901's in the opposite direction with a DE250 horn on top?
I lose the most of the reflections I guess? But gain in a better sound stage.
Secondly, I keep the 901's in the recommended position and place the DE250 or any other tweeter facing rear words in the reflecting position. Of course I will need two tweeters per side to match the design/reflections of the 901's. Overkill?
Have I answered my own questions?
Roland.
Re: B&C DE250/H290 supplement. [message #70390 is a reply to message #70387] Mon, 05 December 2011 16:51 Go to previous messageGo to next message
Again, I wouldn't combine a horn with Bose 901 speakers. Their radiation patterns are just too different.
Re: B&C DE250/H290 supplement. [message #70417 is a reply to message #70390] Wed, 07 December 2011 05:31 Go to previous message
Got your point Wayne.
Would a tweeter like the B&C DE35 be a bad choice as I face difficulty finding dome tweeters this side.
Thanks again.
Roland.
Previous Topic: Do I win a cookie?
Next Topic: 4pi plans
Current Time: Tue May 14 04:21:29 CDT 2024
