Home » Audio » Pro Sound » Recording Banjo/Cumbus
Recording Banjo/Cumbus [message #69154] Wed, 24 August 2011 08:17 Go to next message
LizardBat is currently offline  LizardBat
I need to record a cumbus (sort of a Turkish banjo) and I only have one channel in which to do it. Is it better to try and run a contact pick up off the resonator or take a closely placed omni mic?
Re: Recording Banjo/Cumbus [message #69344 is a reply to message #69154] Mon, 05 September 2011 12:40 Go to previous message
Howdy LizardBat,
I'd say with near certainty you'd get a better sound with the omni mic. If I was recording in a small or sound-treated room, I'd initially try fairly close placement, at somewhere around the neck joint area. Then, I'd move the mic a little at a time towards the bridge and compare the results after each movement.
But, if I had access to a large room with favorable natural reverb characteristics, I'd milk it for all it's worth. I'd use the omni mic placed a bit farther away, to capture some of the natural room ambience.
If the room is too bright, you damp the highest frequencies with strategically placed blankets draped over a makeshift frame. Rolling wardrobe racks are my favorite, but an improvised frame made from PVC pipe is just the ticket if you don't have access to wardrobe racks.
Thermionic
Previous Topic: Test / Practice Recordings
Next Topic: PA Speakers
Current Time: Sat Apr 27 18:06:16 CDT 2024
