Home » Audio » Speaker » Electro Voice TL-606 enclosure with 3 PI components?
Electro Voice TL-606 enclosure with 3 PI components? [message #68174] Tue, 14 June 2011 08:13 Go to next message
themilford is currently offline  themilford
I made a coupla these cabinets for a PA system (TL-606)... I have an extra set of drivers and x-overs for the 3-Pis (Delta12LF and PSD/H290, etc.)
How will this kit perform in these enclosures and will I need to adjust the port?
http://archives.telex.com/archives/EV/Builders%20Plans/TL606%20Builders%20Plans.pdf
Not sure how to calculate this kind of port since it's basically three ports of different size and is along side the cabinet wall...
I could use a little help here.
Cheers,
David
Re: Electro Voice TL-606 enclosure with 3 PI components? [message #68176 is a reply to message #68174] Tue, 14 June 2011 09:25 Go to previous messageGo to next message
The (Helmholtz) box tuning is relatively easy. The Delta 12LF works well in boxes from 3.0ft3 to 6.0ft3 tuned to 30Hz, and can be used in boxes a little larger, up to about 8.0ft3, albeit with slightly lower tuning, from 25Hz to 28Hz. Just about any loudspeaker modeling program (i.e. BoxPlot) can help you calculate this.
The thing to be concerned about is internal standing waves, which will cause ripples in response through the midbass and midrange frequencies. This is where careful midwoofer and port placement helps, and also the right use of damping material inside. I've found it is important to put a sheet of insulation spanning the cross-section in addition to the sheets that line the sides.
As long as the drivers are baffle-mounted, I'd stick with the π crossover and put the woofer and tweeter in the same place relative to each other. This will ensure the forward lobe is clean and properly positioned.
Re: Electro Voice TL-606 enclosure with 3 PI components? [message #68228 is a reply to message #68174] Fri, 17 June 2011 23:24 Go to previous message
The TL-606 cabinets were made for a the EVM 15L's and EVM EVM 15B's (15" drivers), which didn't do anything below 60hz. But there'a an advantage, which is being able to change the baffle board size to adapt the Delta12's which Wayne mentioned. You have between 2.89 cu ft 3.1 cu.ft. to work with based on the size of the driver. Then port length will be based on what freq. you want to tune the cabient to. Run computer simulations like Wayne said, you'll see.
Previous Topic: MTM series or parallel
Next Topic: The Karma Indignia
Current Time: Fri May 17 00:20:54 CDT 2024
