Home » Audio » Speaker » The AudioKarma Econo-Waveguide Speaker (A Waveguide Speaker for the Great Unwashed Masses)
Re: The AudioKarma Econo-Waveguide Speaker [message #67185 is a reply to message #67017] Sat, 23 April 2011 09:36 Go to previous messageGo to next message
Here's the BOM. All parts from Parts Express. The total cost of the parts for a stereo pair is about $440. (For a stereo pair order two of each unless otherwise noted):
16 ohm 10 W resistor #004-16
25 ohm 10W resistor #004-25
2 ohm 10W resistor #004-2 (in series with 25 ohm resistor)
8 ohm 20W resistor #017-8 (woofer zoebel)
0.47uF capacitor #027-406
4.7uF capacitor #027-422
10uF capacitor #027-428 (woofer zoebel)
12uF capacitor #027-430
#8 X 3/4 screws black 100 pcs #081-422 (one pkg required)
1/4" female disconnects 50 pcs #095-290 (one pkg required)
Speaker binding post #260-303
Eminence Delta-12LFA #290-416
0.60mH 18awg air core inductor #255-234
1.5mH 15awg air core inductor #255-426
2.5" flared port tube #260-478 (two required per speaker)
Selenium D220Ti-8 driver #264-270
H6512 waveguide #270-318
These speakers are capable of sustained high power/output levels, but only if you quadruple the wattage ratings of all the resistors. For typical home audio levels the 10 and 20 watt capacities in the BOM are ok, because they will play to room filling levels with only a few watts.
If you don't have the equipment to build diy enclosures you can use the ($69/ea) Parts Express flat pack trapezoid birch cablnets #245-324. (Be sure to cut all the holes before you assemble them). These are marginally small for the Delta 12LFA and will have little output below 70hz, so you'll want to use a subwoofer with them.
Re: The AudioKarma Econo-Waveguide Speaker [message #67649 is a reply to message #67185] Mon, 16 May 2011 10:43 Go to previous messageGo to next message
A few LSAF visitors asked me to post in one place all the information needed to build a pair of EconoWaves like the ones I exhibited using the Eminence Delta 12LFA driver. So here it is:
The crossover is almost identical to the original one in the Audio Karma Econowave thread. Here's the link:
http://www.audiokarma.org/forums/attachment.php?attachmentid=151281&d=1242968714
This crossover is a generic prescription for almost any woofer. I made three specific changes to better accommodate the Eminence woofer:
1) In the woofer crossover I added a zoebel consisting of an 8 ohm 20 watt resistor in series with a 10uF capacitor. The zoebel is installed parallel to the 12uF shunt capacitor, connecting the positive and negative woofer terminals.
2) For the series resistor in the tweeter L-Pad I used a 25 ohm resistor in series with a 2 ohm resistor for a total of 27 ohms. This voices the tweeter a bit on the quiet side, and other builders may prefer to use only the 25 ohm.
3) I ommitted the variable L-Pad, instead trying different fixed resistor combinations until the speaker tested and sounded the way I like it.
All the parts are sourced from Parts Express. The total cost of the parts for a stereo pair is about $440.(For a stereo pair order two of each unless otherwise noted). I assume you will supply your own wire and will line opposite interior walls of the enclosure with R-13 fiberglass insulation from Home Depot.
Small DIY Enclosure (Seen at LSAF) Details
The pair I exhibited were in an approximately 2 cu ft enclosure, which is marginally small for the Delta 12LFA. I would use this enclosure only if you know you will be using a subwoofer. In other words, it's a good choice for HT use, but not the best for music only use. The enclosure dimensions are 16"W, 13.5"D, 24"H.
For driver and port placement look at the picture and consider this: The tweeter is mounted with the outside of its flange about 1" from the top of the enclosure. The woofer is positioned with its frame about 1" from the tweeter. The ports are centered in the available space below the woofer. You should determine the proper mounting positions by placing the drivers and ports on the front baffle and marking their position with pencil.
This enclosure has one "window-frame" brace between the woofer and tweeter.
Large DIY Enclosure Details
This is the preferred enclosure for music use without a sub. The dimensions are 16"W, 13.5"D (same as the small enclosure), but 40"H. This height places the center of the tweeter horn at 36" seated ear level. I recommend three window-frame braces, one between the wooofer and tweeter, one just below the woofer, and one halfway between the below-woofer brace and the enclosure bottom. The drivers are mounted the same distances from the top of the enclosure as in the small enclosure. One 4" port (PE #260-411) should be used cut to 3" length. The port can be centered on the front or the back, midway between the lowest two braces. Front mounting is preferred if the speaker will be placed close to the back wall.
I plan to build this version soon and will post construction pictures here.
PE Flat Pack Trapezoidal Enclosure Kit Details
Here's some really good news for anybody who wants to build this speaker but doesn't have the equipment to build DIY enclosures. You can build a pair of the $69 Parts Express flat pack enclosures using only an electric drill, a skil saw, and a screwdriver. Here's the link to this product:
The folks at PE were kind enough to supply the kit with an 11" hole to accommodate any 12" pro woofer. You must cut the rectangle for the tweeter. Place the tweeter on the baffle with the woofer already set in place, position it one inch from the woofer, draw the outline of the tweeter, and use that as a guide to cut the tweeter hole.
This does not leave enough space on the front for the ports, so you will use a single 3" port (PE #260-404) on the back panel. This port is already the required 4.5" length, so no cutting is needed. Center the port so its inside opening isn't blocked by either the woofer or the tweeter magnet. A good location would be about halfway between the woofer and tweeter center lines.
This enclosure is a bit smaller than the one I exhibited at LSAF. The F3 will be about 60hz, and a subwoofer is highly recommended.
If you visited my room at the LSAF and you plan to build the AudioFred EconoWave, PM me for the "Show Special" price on the parts. If you were unable to attend the LSAF you can get the parts directly from Parts Express.
Re: The AudioKarma Econo-Waveguide Speaker [message #68083 is a reply to message #67017] Tue, 07 June 2011 17:50 Go to previous messageGo to next message
The AudioFred AudioKarma EconoWaves continue to evolve, first with the replacement of the 2 cu ft standmount enclosure with a 4 cu ft floorstander, and then with the addition of a rear-firing bipolar waveguide tweeter. The larger enclosure has extended the bass response enough for these speakers to sound good without a subwoofer. For the rear-firing tweeter I used a Dayton 6X6 waveguide with an Eminence ASD-1001 compression tweeter.
index.php?t=getfile&id=471&private=0
  • Attachment: 006.JPG
    (Size: 494.26KB, Downloaded 15593 times)
Re: The AudioKarma Econo-Waveguide Speaker [message #68084 is a reply to message #68083] Tue, 07 June 2011 17:52 Go to previous messageGo to next message
Here's a picture of the back of the new enclosures showing the waveguide, the 4" port and the speaker terminals. A miniature switch on the speaker terminals allows me to turn the rear firing tweeter on or off:
index.php?t=getfile&id=472&private=0
  • Attachment: 005.JPG
    (Size: 503.19KB, Downloaded 14137 times)
Re: The AudioKarma Econo-Waveguide Speaker [message #68085 is a reply to message #68084] Tue, 07 June 2011 18:19 Go to previous messageGo to next message
That larger box looks great! I'll bet it sounds good too.
Re: The AudioKarma Econo-Waveguide Speaker [message #68188 is a reply to message #68085] Tue, 14 June 2011 21:56 Go to previous messageGo to next message
Since I've upgraded to larger enclosures the smaller ones that I was demonstrating at the LSAF are free for anybody who's willing to pick them up at my house in Houston. PM me if you're interested.
Re: The AudioKarma Econo-Waveguide Speaker [message #69426 is a reply to message #67026] Fri, 09 September 2011 18:12 Go to previous messageGo to next message
Wayne Parham wrote on Tue, 12 April 2011 12:41
You might want to also measure the verticals to make sure your forward lobe is right.
Finally got around to doing this, and the result wasn't pretty. The upper lobe with the stock Econowave crossover is about 10 degrees above perpedicular. This places it exactly in the path to the ears of a standing listener. I never listen standing, but that's still a narrow angle.
I had the right parts in the bin to convert the tweeter crossver to a 3 Pi. In fact, I had a 6.8uF Clarity SA cap (good) and a 20uF Northcreek Zen cap (better). With the 3 Pi crossover the null has moved up to where you measured it in your video, well above the ears of even a standing listener.
I also found the 3Pi third-order crossover sounds better than the Econowave crossover, so it will stay in the speaker. The improvement isn't subtle; it's enough to elevate the sound quality of this speaker from being a "good sounding" speaker to one that's truly involving. The improvement isn't due to better parts because I used Jantzen Z Superior caps in the old crossover. I've noticed with several speakers that assymetrical crossovers (e.g. 2nd order woofer, 3rd order tweeter) sound better to my ears.
Re: The AudioKarma Econo-Waveguide Speaker [message #69433 is a reply to message #69426] Fri, 09 September 2011 22:03 Go to previous message
Yes, you really have to dial in speakers like these for best results. It's what separates the good speakers from the great ones, even more than the horn chosen. I mean, a bad horn can't be fixed, so I'm not saying one of those spitty CD horns will sound as good as a radial or waveguide. But I am saying that the crossover is as important, really even more so, and that even if you have an excellent waveguide, with the wrong crossover, the speaker will not sound good. Like you noticed, if the null is in your face, the response is horrible. That's the biggest problem for the round horn guys, you can't dial in the crossover, it just isn't possible.
Previous Topic: Making 3.1 into 5.1 Setup
Next Topic: 3-Way Speakers for My Car
Current Time: Wed May 08 02:11:07 CDT 2024
