Home » Sponsored » Pi Speakers » Horn for 3pi?
Horn for 3pi? [message #68141] Sat, 11 June 2011 18:12 Go to next message
Slybean is currently offline  Slybean
Hi
I finally have time for the 3pi speakers. I have 2 questions. Which horn model is required for the 3pi? Is the woofer rear mount or front or flush mounted?
regards
s
Re: Horn for 3pi? [message #68147 is a reply to message #68141] Sun, 12 June 2011 08:38 Go to previous messageGo to next message
The horn is the Eminence H290. Woofer and horn can be routed flush or (front) surface mounted. Just do them both the same way - If one is routed flush, both should be routed flush.
Re: Horn for 3pi? [message #68148 is a reply to message #68147] Sun, 12 June 2011 09:32 Go to previous messageGo to next message
Your xovers is design for front mount or flush?
s.
Re: Horn for 3pi? [message #68152 is a reply to message #68148] Sun, 12 June 2011 13:05 Go to previous message
It's the same, as long as both are routed flush or both are surface mounted. No measureable difference.
Previous Topic: 4 Pi and 1 Pi plan request
Next Topic: 4Pi Port Options
Current Time: Thu May 16 07:52:24 CDT 2024
