Home » Audio » Speaker » How important are speaker wires?
icon14.gif  How important are speaker wires? [message #63350] Thu, 08 July 2010 02:22 Go to next message
rockhound is currently offline  rockhound
I know a bad quality wire is not good for speakers, but some of the real heavy duty wires are very expensive. What gauge, composition or brand is considered the best quality and value?
Re: How important are speaker wires? [message #63352 is a reply to message #63350] Thu, 08 July 2010 09:21 Go to previous messageGo to next message
I prefer a good, large (guage), high-quality, stranded zip cord. Belden makes good cable, and there are a lot of others that make good cables too. It's not real high-tech, more just good quality materials.
Re: How important are speaker wires? [message #63353 is a reply to message #63350] Thu, 08 July 2010 10:15 Go to previous messageGo to next message
Asking questions about cables invites a flame war because to many it is almost a religions thing, but....
Every piece of equipment in the chain acts a a tone control -- equalization if you will. Your choice of amps, speakers, even the medium affect the sound of what the engineer put on the recording. Choice of cables is yet another tone control. That said:
The only thing of any great significance is the LCR characteristics of the cable. L and C are pretty much a trade off. Increasing L decreases C and vis versa. Most people opt for increased C because L rolls of the top end. You must be careful to not make C so large that you drive your amp into oscillation, if that is an issue.
What remains is R. You need a wire guage large enough to keep ohmic loss to an acceptable minimum. Anything else is a waste of copper. You need to figure out what your maximum power level is and then do the math. when you arrive at an ohmic loss that you can live with, that is the size wire you need.
In my case, I use rather high efficiency speakers and never exceed 10w/ch. This means that I can use single pairs of CAT5 and get less that 1dB loss in a 2m run. If you are using 85dB/w/m speakers at 100's of watts, your answer will be different.
Bob
Re: How important are speaker wires? [message #63372 is a reply to message #63353] Sat, 10 July 2010 21:56 Go to previous message
Keith Larson is currently offline  Keith Larson
With a decent wire, making a good connection is the next most important thing to consider. Crummy connectors, Wire oxidation/corrosion, Banana jack screws that come loose are a few things that come to mind.
BTW, what 'looks' like a good connector can be deceiving. Gold plated jacks are sometimes plated after the underlying base metal pieces are assembled. The crimp connections are not gold plated.
Keith
Previous Topic: Fix or chuck it?
Next Topic: Need Tweeters
Current Time: Sat Apr 27 09:29:51 CDT 2024
