Home » Sponsored » Pi Speakers » Port Tube Needed for 2Pi Towers?
Port Tube Needed for 2Pi Towers? [message #62180] Wed, 24 March 2010 21:41 Go to next message
breakfastchef is currently offline  breakfastchef
I built these speakers almost two years ago. The plans showed a bass port, but no port tube. Is one needed for the 2Pi towers? If so, what should be the length.
Re: Port Tube Needed for 2Pi Towers? [message #62184 is a reply to message #62180] Thu, 25 March 2010 00:54 Go to previous messageGo to next message
The two π towers don't use a port tube. The duct is just a large hole in the rear of the cabinet.
Re: Port Tube Needed for 2Pi Towers? [message #62430 is a reply to message #62180] Wed, 28 April 2010 18:26 Go to previous messageGo to next message
dB is currently offline  dB
In case the wood panel isn't of the same thickness (this being the port length, in case there was some differences) of the original Pi-Speaker project, you can recalculate the diameter of the port, for the same tunning frequency. Confused
Port Size for 2Pi Towers [message #62431 is a reply to message #62430] Wed, 28 April 2010 19:22 Go to previous message
That's right. The plans show port diameters for 5/8" or 3/4" panel thickness. Others are shown here:
For 5/8" wood stock, cut a 4.5" diameter port hole.
For 3/4" stock, cut a 4.625" hole.
For 1", cut the hole 4.75" diameter.
For 1.5", cut the hole 5.125".
Previous Topic: looking at 6 Pi's
Next Topic: 7 pi plans
Current Time: Sun Apr 28 22:09:34 CDT 2024
