Home » Sponsored » Pi Speakers » Questions on the 12 and 3 pi subs
Questions on the 12 and 3 pi subs [message #53468] Sun, 26 April 2009 16:08 Go to next message
Pfenning is currently offline  Pfenning
First off can I get plans for both?
I am looking into these for some buddies of mine that have a band. They really need to fill in the bottom end with some good bass. I purchased a pair of stage 4's from you years ago, and haven't been in the mood for new speakers since. They are awesome, and when my buddies were talking about a sub, you were the first guy I thought of. Here's my questions.
What material do you recommend the sub boxes be built out of?
Would a single 12 pi sub driven with 800 mono watts be better than 2- 3 pi subs driven with 400 watts each?
Is the bass from the 12 pi directional, like a typical horn is?
Is the heat exchanger required, and can it be added later?
Do you have people using 12's and 3's in bands now?
How much does the 12 wieght? It looks huge?
Thanks
Re: Questions on the 12 and 3 pi subs [message #53469 is a reply to message #53468] Sun, 26 April 2009 17:50 Go to previous messageGo to next message
Check your mail - I've sent plans.
When using subs for prosound, use baltic birch. It's much more durable and it's lighter than MDF too.
You decision about whether to use one 12π hornsub or a small group (say four) of the three π subs should be entirely dictated by your intended usage. If you'll be playing mostly indoor events, small to medium size rooms, then the group of three π subs is better. If you'll be playing in very large rooms or outdoors, then the 12π hornsub is best.
I have lots of both models of subs in the field, and the lines are very clearly drawn about who uses what. I only know of one person using a 12π hornsub for home hifi. It's just too large and doesn't make sense for small and medium size rooms. The intended environments are outdoors or very large rooms like stadiums, auditoriums or large theaters.
Likewise, the three π subwoofer is mostly in homes. I have a few being used by DJ's and bands that do events in local clubs and other moderate sized rooms. In small to medium size rooms, it's much better to have a few three π subs than it is to have one or two hornsubs. With multiple subs, you can smooth room modes, so that makes it handy to have several three π subs to place around. They're pretty easy to carry too.
The 12π hornsub is 45x45x28 and weights 285 lbs. It is a big box, to be sure, but it rocks back on its wheels which fit perfectly on truck ramps of everything from 24' rentals to the biggest tractor trailers.
The mouth frontal area is large enough to make the basshorn directional at the top end of the passband, but down low it is acoustically small. That's why a single horn has approximately 6dB rising response through its passband. However, when used in small groups, the frontal area is large enough to provide directivity through the whole passband, and there no longer is rising response. You can see the difference even when just using a pair of horns, and by four, response is a straight flat line. Tons of power too, by the way.
You can build the horn without the heat exchanger, but I wouldn't recommend it. I've already done all the hard work, so to ignore it just doesn't make sense. We have the PI-12 woofers, already machined and ready to accept the cooling plugs. We keep them in stock, as well as the plugs and plates. I'm not sure if you read the write-ups of test results, but the improvement made by the plugs is incredible. Running the horn without the cooling plugs is like running a car without a radiator. Sure, it will start and run but it won't produce as much power and it won't last as long.
Re: Questions on the 12 and 3 pi subs [message #53470 is a reply to message #53469] Sun, 26 April 2009 22:14 Go to previous messageGo to next message
OneBean is currently offline  OneBean
Wayne, thanks for the advise and the plans. As far as powering the pi 3's, what should I plan on. We have a large pro audio Altec amp that is advertised as 400 x 400. I'm not sure if it's 2 ohm stable. Are the 3's 8 ohm or 4 ohm? Sounds like 3's are the way to go with most of the gigs being in small bars. Is that what your recommending?
OneBean
Re: Questions on the 12 and 3 pi subs [message #53471 is a reply to message #53470] Mon, 27 April 2009 00:49 Go to previous message
Yeah, in small bars, I'd rather use a multisub approach. It's also pretty easy to transport and carry a few three π subs.
Now if outdoors, even if on a small stage like at a state fair or Octoberfest or something, that's when you want the 12π hornsubs. Use enough for the SPL required. One or twenty-four, you'll get high-quality, deep, smooth output.
Back to the three π subs, they're each a 4Ω load and they'll each handle 400wrms. You could run one per channel or you could connect four in series/parallel and bridge the amp.
Don't skimp here, I'd use at least two for each of your mains and it wouldn't be out of the question to go for a ratio of 3-to-1 or even 4-to-1. Indoors, the more you have the better, and scatter them all around for best results.
That is exactly the opposite thing you would want to do outdoors or in a very large room. Outdoors, you want to group the subs together, close to the mains if you can. For coverage, most times they're grouped on each side but the point is that outdoors or in large spaces you want all sound sources within 1/4λ, or at least as close as possible.
Many people think this applies indoors too, but it doesn't. Indoors, standing waves and reflections from walls make interference that will be further than 1/4λ from the source. This self-interference causes deep notches at certain bass frequencies in various places throughout the room. By using several subs placed around the room, holes from self-interference from one sub will be filled by another. That's why it is good to spread them around spacially. It tends to average out the sound field and make bass response smooth and uniform throughout the room.
The moral of the story is to use as many subs as you can afford, and spread them around. Space them apart in all three dimensions, several feet apart. Put a few across the stage, put a couple up off the ground, put some at the front of the stage and some further back. Using several subs will help give you enough SPL in the bass range and it will also smooth the sound field. Where indoors bass is concerned, using the multi-sub concept, you can't have too many subs because you can always turn the power down. The more positions you have subs placed, the smoother and fuller it sounds.
Previous Topic: 2 Pi Plans
Next Topic: Eight-Pi woofer
Current Time: Thu May 02 14:00:59 CDT 2024
