Home » Sponsored » Pi Speakers » LaScala
LaScala [message #52102] Mon, 05 May 2008 20:31 Go to next message
What is the Bass response on a 1980 Lascala ??? To me it sounds like it drops
off rapidly after 90 hertz . Thanks for your reply Wayne. Are you up on this type of folded horn.
Re: LaScala [message #52103 is a reply to message #52102] Mon, 05 May 2008 23:31 Go to previous messageGo to next message
You're right, they don't do much below 60Hz. They're cool looking but have some acoustic warts.
Re: LaScala [message #52104 is a reply to message #52102] Wed, 07 May 2008 11:51 Go to previous messageGo to next message
loudnclear is currently offline  loudnclear
The new Lascala made by Klipsch has been re-voiced using crossover tweaks. Aftermarket xovers by others can accomplish the same result on older LS. Basically, they tighten the slopes, notch out resonances, and lower the MF and HF to bring out the bass better.
Re: LaScala [message #52120 is a reply to message #52102] Wed, 14 May 2008 17:26 Go to previous messageGo to next message
Frode is currently offline  Frode
If you want more bass, you could always try djk's bass reflex mod.
Frode
Re: LaScala [message #52174 is a reply to message #52120] Wed, 28 May 2008 21:59 Go to previous message
I already have made the bass mod, and it adds a truck load of bass to the LaScalas. Without the bass mod the speakers by themself are good for P.A.only in my book . And I have knocked the midhorn down about 4-5 Db. Thanks for the reply and info.
Previous Topic: alpha 6 horns
Next Topic: 4 pi JBL2226
Current Time: Sun Apr 28 18:17:50 CDT 2024
