Polar, not bears. [message #51213] |
Thu, 28 June 2007 16:17 |
Zene Gillette
Messages: 88 Registered: May 2009
Viscount |
Wayne ... What is the standard acceptable polar pattern (horizontal and vertical) for matching speaker crossover points and keeping good dispersion, if there is one? Need the included angle and -dB figures. Also, is there a good article on same? Thanks, Zene
Re: Polar, not bears. [message #51214 is a reply to message #51213] |
Thu, 28 June 2007 16:51 |
Messages: 18688 Registered: January 2001
You can design a speaker with any directional pattern you like. Prosound speakers tend to be offered with narrower patterns than home hifi speakers. For example, you can find prosound speakers with 90°, 60° and even 40° patterns. Most home hifi speakers have wider patterns than that, since most are direct radiators. They also tend to have non-uniform directivity, since direct radiators begin to focus sound into a narrower spread as frequency rises, then at the crossover points the pattern widens again. I personally don't like the way that sounds, because it makes a non-uniform reverberent field, which sounds unnatural to me. The sound reflected back to you from the environment is tonally off. So I prefer a speaker that radiates uniform energy throughout the angle of coverage, preferably constant or at least uniformly collapsing without abrupt changes through the audio band.
