Home » Sponsored » Pi Speakers » 2226 tuning help needed!
2226 tuning help needed! [message #49792] Fri, 28 July 2006 09:52 Go to next message
spkrman57
Wayne,
Looking for comments on this configuration:
2226J in 3.5 cubic ft box tuned with (2) ports 4" ID and 6.5" long.
Results from WT2 come up with this:
Fsb = 45.7hz
alpha = .955
Ha = .78
Fm = 35.67hz
flo = 23.5hz (67 ohm)
fhi = 69.3hz (80 ohm)
My listening detects a large hump around 60hz.
Could you recommend a port tuning change (shorter ports I'm thinking) to get back to flatter response.
JBL recommends (2) 4" ID ports @ 4" long for a 4 cubic ft box. Would you agree that shortening the ports from 6.5" to 4" would be close to optimum?
Cabinets arrived to me as described, so I knew a port change would be necessary.
Thanks, Ron
Re: 2226 tuning help needed! [message #49793 is a reply to message #49792] Fri, 28 July 2006 10:08 Go to previous messageGo to next message
I think that alignment would work great outdoors or in a very large room, but indoors it might sound peaky especially in a smaller room. I like a slightly overdamped alignment for this driver, so I tune the cabinet about 10Hz lower.
Re: 2226 tuning help needed! [message #49794 is a reply to message #49793] Fri, 28 July 2006 12:22 Go to previous messageGo to next message
spkrman57
Wayne,
I take your answer as meaning to extend the ports a few inches longer, say 8" long each vs 6.5" that are in there already.
Thanks, Ron
Re: 2226 tuning help needed! [message #49796 is a reply to message #49794] Sat, 29 July 2006 00:32 Go to previous messageGo to next message
Yes, making the ports longer would certainly shift the Helmholtz frequency down. I'd go down about 10Hz, so I'm thinking you may have to go longer or even plug a port.
Plugged one port. [message #49797 is a reply to message #49796] Sun, 30 July 2006 11:10 Go to previous messageGo to next message
spkrman57
Used foam pieces that I keep around. That way I can just remove it with no ill effects.
Sounds like what I will use for awhile.
Thanks Wayne!
Ron
Re: Plugged one port. [message #49798 is a reply to message #49797] Sun, 30 July 2006 11:31 Go to previous messageGo to next message
Very good! That'll work!
Re: Plugged one port. [message #49799 is a reply to message #49797] Sun, 30 July 2006 19:40 Go to previous messageGo to next message
"Sounds like what I will use for awhile."
I give it two days......
Think I can't leave things alone for too long? [message #49800 is a reply to message #49799] Sun, 30 July 2006 20:22 Go to previous message
spkrman57
Of course Colin, you may be right!!!
Ron
Previous Topic: Difficult Technical Question
Next Topic: Latest One Pi Towers
Current Time: Tue May 14 14:12:05 CDT 2024
