Home » Sponsored » Pi Speakers » Wayne - Crossover values for 2 x 16-ohm motors in Four-Pi Pro
Wayne - Crossover values for 2 x 16-ohm motors in Four-Pi Pro [message #49407] Sun, 30 April 2006 07:18 Go to next message
ccvogel is currently offline  ccvogel
Wayne,
If I ratio the nominal impedances [ie, 8 to 16] and back substitute into your 1K6a012dB crossover circuit for a Four-Pi Pro, I get the following values:
Woofer:
C4 = 5 uF
L2 = 2.0 mH
Tweeter:
C2 = 4 uF
C3 = 11 uF
L1 = 1.2 mH
Referrring to the thread below on 16-Ohm CD compensation circuits, we have:
C1 = 0.33 uF
R1 = 50R
R2 = 16R
Do these values work well, or have I missed something?
Thanks for help,
ccvogel
Re: Wayne - Crossover values for 2 x 16-ohm motors in Four-Pi Pro [message #49414 is a reply to message #49407] Mon, 01 May 2006 09:21 Go to previous messageGo to next message
Use the values of C1, R1 and R2 with the stock (8Ω) crossover. The load on the crossover is formed by the driver and the components C1, R1 and R2, and this is a solution that works well with R1=50Ω, R2=16Ω and C1=33uF. Summing is good and the initial shelf is nice and flat with compensation coming in at the right frequency.
Re: Wayne - My real question [message #49416 is a reply to message #49414] Mon, 01 May 2006 10:15 Go to previous messageGo to next message
I'm afraid my question was poorly stated. What I'm really asking is for ALL of the Four-Pi crossover component values when both the 2226 and 2426 are 16-Ohm versions.
Thanks,
ccvogel
Re: Wayne - My real question [message #49418 is a reply to message #49416] Mon, 01 May 2006 10:39 Go to previous message
Oh, I see now, gotcha. The tweeter is the hard one though - the midwoofer is easy 'cause it just has one series coil. Double it, go with a 1.4mH coil L2.
Previous Topic: Budget "Classic" Two Pi Drivers
Next Topic: Theatre 3 Pi Crossover
Current Time: Sun May 19 17:58:10 CDT 2024
