Home » Sponsored » Pi Speakers » Altec + JBL =PI four?
Altec + JBL =PI four? [message #47821] Thu, 29 September 2005 18:16 Go to next message
beto1 is currently offline  beto1
Hi,
sorry, but this is a question from an ignorant:
Can I use a pair of 802-D (811-B horn)16 Ohms Altec compression drivers with a pair of 2226H JBL woofers? In summ, can I use 16 and 8 Ohms drivers together? All this to drive an Audio Note Kit One, 300B SET amp with 8 and 4 Ohms outputs.
Thanks in advance,
Beto.
Re: Altec + JBL =PI four? [message #47823 is a reply to message #47821] Fri, 30 September 2005 02:31 Go to previous messageGo to next message
That makes a very nice combination. Several people here have done exactly that.
Re: Altec + JBL =PI four? [message #47824 is a reply to message #47823] Fri, 30 September 2005 08:14 Go to previous messageGo to next message
Hi Wayne,
Bill told me that I have to use an attenuation matrix. My idea is to build the 4 PI speakers, with 2226H woofer and Eminence tweeter, but in the meantime, some guy offer me this vintage drivers.
Also, this change the enclosure, of course.
Regards,
Beto
Can some JBL+ALTEC share.... [message #47832 is a reply to message #47823] Sat, 01 October 2005 23:04 Go to previous messageGo to next message
Can some PI, JBL(8)+Altec(16) owner can share his experience....,
(300BSET to hear "in the flat field" bauhaus stuff?)
Re: Can some JBL+ALTEC share.... [message #47833 is a reply to message #47832] Sat, 01 October 2005 23:38 Go to previous messageGo to next message
I'm sure some of the guys that have systems like that, but in the meantime, here's a list of Altec posts:
Re: Can some JBL+ALTEC share.... [message #47835 is a reply to message #47833] Sun, 02 October 2005 05:06 Go to previous messageGo to next message
spkrman57
I've done in in the past and Epstein also!
Ron
Re: Can some JBL+ALTEC share.... [message #47836 is a reply to message #47835] Sun, 02 October 2005 05:09 Go to previous messageGo to next message
spkrman57
Sorry, should add more info.
I used 15 ohm parallel and 30 ohm series w/.47 ufd parallel for the bigger metal horns.
Works quite fine in my mind!
Regards, Ron
Re: Altec + JBL =PI four? [message #47838 is a reply to message #47821] Sun, 02 October 2005 15:38 Go to previous messageGo to next message
JLapaire is currently offline  JLapaire
Beto,
I'm using something like that right now - JBL 2446j 2" 16 ohm compression drivers with Eminence Delta Pro-15 8 ohm bass drivers. Less padding is needed on the HF is all.
John
THANKS [message #47843 is a reply to message #47833] Mon, 03 October 2005 07:35 Go to previous message
Thank you Wayne and all you guys!
Yes , I have started my search in this forum with "altec" word. I apreciate a lot all your posts.
Regards,
Beto
Previous Topic: Request for plans for Pi 7 & 10 bass bin
Next Topic: Paging Kevin Trancemitr
Current Time: Mon Apr 29 03:00:55 CDT 2024
