Home » Sponsored » Pi Speakers » 2Pi Tower is "sneaky big"! How will it model with.........
2Pi Tower is "sneaky big"! How will it model with......... [message #46509] Thu, 17 March 2005 22:09 Go to next message
Got my 2Pi upgrade kits today. They're for an experiment Speakerman wants me to try: a pair of 12" Altec/University from his archives with the Vifa in a 4.5 cu ft sealed box. We figure if it has to be ported then it's just a matter of drilling another hole as there's no depth to the Tower port.
I was amazed to find the O.S. dimensions of the Tower yield 5.5 cu ft! But by the time the bracing, Hardi-Backer a la Bob Brines and drivers are installed it should be closer to 4.5.
Of course it has to stop raining on my alfresco workshop so I can build.
Re: 2Pi Tower is "sneaky big"! How will it model with......... [message #46511 is a reply to message #46509] Fri, 18 March 2005 09:35 Go to previous messageGo to next message
Sounds interesting. Do you have T/S specs?
T/S for 12" driver [message #46516 is a reply to message #46511] Sun, 20 March 2005 07:35 Go to previous messageGo to next message
spkrman57
Wayne and Bill,
My "woofer tester" is currently not running on the pc, but I had measured these back some time when everything worked with my woofer tester, and found out they are identical to the Altec 414 specs.
From my memory: fs= 30hz, qts = .35 eff = 96db Vas = fuzzy memory says 10 to 20 cubic ft.
Sorry I can't remember more than that. I do remember these measured same as Altec 414's as I measured the 414's and the (Altec/Utah???)'s at the same time and were identical. The 414's of course had cast frames and alnico magnets, the clones are (40 - 60 oz/ceramic) magnets, stamped frames.
I don't frequent the Altec website much anymore so unsure, I have become a JBL junkie!
Ron
Re: T/S for 12" driver [message #46522 is a reply to message #46516] Sun, 20 March 2005 09:33 Go to previous messageGo to next message
The Altec 416 has very high Vas and so needs a very large box, between 6 and 18 cubic feet tuned to 30Hz. PiAlign suggests 8.5ft3 for the 416. The Altec 414 should be used in much smaller boxes, like 0.5ft3 to 2.0ft3 tuned to 60Hz. PiAlign suggests 1.5ft3 for the Altec 414.
Re: T/S for 12" driver [message #46526 is a reply to message #46522] Sun, 20 March 2005 10:04 Go to previous message
spkrman57
Thanks Wayne,
Bill's cabinet is larger than that, but is also sealed(at least so far). It will be interesting to see the results Bill comes up with.
Ron
Previous Topic: Comments on the two π tower
Next Topic: Sure, I could have just done a search,...
Current Time: Wed May 15 15:37:55 CDT 2024
