Driver Is Blown :( [message #45027] |
Wed, 21 July 2004 12:03 |
Fresno
Messages: 41 Registered: May 2009
Baron |
I made the Pi 2 tower about 2 years ago and one of the drivers has blown. I'm not sure what blew it, it is probably one of these 3 things: 1. Digital Clicking - Sometimes untranslated DVD clicking made it through to the speakers. 2. The RCA tube amp/preamp that I hooked up to the speakers was not a perfect fit and it ruined the speakers. 3. My son plays a lot of base-heavy music, and I'm sure very loud when I'm not home. But anyway, I want to replace the (10") drivers. I could just replace them with the same drivers as before, but I'd like to know what my options are. How would a bigger (12") driver do in the same box? What would I do with the piezo electric tweeter? Is there a different 10" driver that would do better? I know Wayne specifically designed the box for this speaker combo, but do I have any options? Thanks in advance. FWIW - I've included a link to my speaker pic. http://www.pispeakers.com/DIY/Steve_Nash_Tower_two_Pi.jpg Thanks James W Johnson for linking to it!
Re: Driver Is Blown :( [message #45028 is a reply to message #45027] |
Wed, 21 July 2004 13:32 |
James W. Johnson
Messages: 199 Registered: May 2009
Master |
I made the Pi 2 tower about 2 years ago and one of the drivers has blown>>>>>>>>>>>>>>>>>>>>>>>>>> If it makes you feel any better I blew 3 woofer in 6 months on my Klipsch Reference series speaker that I just sold. (good ridence too!) I blew at least 10 tweeters on my Adire Kit 281s over the course of 3 or 4 years. Maybe its time you step up to something a little beefier , I am sure your Son would appreciate it as well! :-)
Couple of Upgrade Options [message #45030 is a reply to message #45027] |
Wed, 21 July 2004 15:01 |
GarMan
Messages: 960 Registered: May 2009
Illuminati (2nd Degree) |
Fresno, One option for upgrade would be to convert the Towers into a pair of Theater Three's. The volume between the Towers and the Three's are close enough and I'm sure your son would appreciate the improvements in the bass. The port will need to be resized. However, whether a 12" driver will fit on your baffle will depend on the location of your internal braces. Also, if you followed Wayne's intructions for baffle cutout on the Towers, you might be short about 1/2" for the compression horns. I know because I've tried. Gar.
Warrantee? [message #45040 is a reply to message #45035] |
Wed, 21 July 2004 20:51 |
Fresno
Baron |
How long is the warrantee on those puppies? I think I got them last summer. What is the procedure for returning them? Since only 1 is blown I'd want 2 new ones to avoid a mismatch. I was using a 35 WPC push pull tube amp, the bass was a bit boomy on some of my CD's but not most. His music cracked the foundation of the house next door :)
Re: **Warranty** (nt) [message #45045 is a reply to message #45041] |
Thu, 22 July 2004 00:31 |
Messages: 18691 Registered: January 2001
If I remember correctly, both spellings are correct. As for the matter at hand, just send 'em back to me and I'll send them on to Eminence. If they are able to warranty them, they will. I'm not sure I'd send the good one though. They won't warranty a good speaker. If there's a factory defect of some kind, you bet they will. But they won't send a matched pair or anything like that. New devices are expected to meet specs, and they are examined by QC but that's the extent of it. That does bring up an interesting issue though. Just like some people buy tubes in bulk and then test them to provide matched pairs, this could be done with loudspeakers also. Probably best to do it on the expensive devices, since the service would add considerable cost. But it is an interesting idea.
Consideratons [message #45053 is a reply to message #45035] |
Fri, 23 July 2004 15:56 |
Fresno
Baron |
Ok, do I ship it to you or do I ship it to them? If they don't warrantee/y it, what would be your suggestion regarding going with the 12" (if it fits)? Assuming it would not be the best cabinet for the 12", would the 12" still be better than the 10" for the cabinet? Would the piezo electric tweater fit well physically and sonically? Steve
