New music room in a few easy steps [message #4461] |
Tue, 24 July 2007 23:28 |
colinhester
Messages: 1349 Registered: May 2009 Location: NE Arkansas
Illuminati (3rd Degree) |
Step 1: Dig big hole
Step 2: Cut foundation wall
Step 3: Knock out foundation section
Step 4: Pour footers
More tomorrow.....C
"False wall" bass trap panels for concrete walls [message #4465 is a reply to message #4464] |
Wed, 25 July 2007 12:51 |
Messages: 18691 Registered: January 2001
Many homes have rooms with framed drywall construction. The flexibility of framed drywall with insulation behind it actually helps to damp room modes. The walls move and absorb some energy, providing a great deal of damping.But having concrete walls, you might need to add some large dampers. Some people use round tubes filled with absorbent stuffing, but I prefer panels. They're simple, really, basically adding framed walls inside your concrete walls. You'll make a sort of a false wall spaced several inches out and fill it with insulation. You don't want the panels to be braced, you want them to vibrate. Their size determines their resonance, which in turn determines the frequency they'll damp the most. Their effectiveness is also a function of their position, because you want them to be placed on nodes. That's where they'll damp the most. Then again, for aesthetics, it might be best to make a false wall span the entire length of each wall with panels sized to damp the frequencies that are most troublesome. You can find your room modes by measurement or with a program like CARA.
Re: Find Jimmy Hoffa? [message #4466 is a reply to message #4461] |
Thu, 26 July 2007 03:02 |
Bill Epstein
Messages: 1088 Registered: May 2009 Location: Smoky Mts. USA
Illuminati (2nd Degree) |
I'm amazed the town let you do that on the side and not the back. Be sure and put a ramp next to the stairs so the IRS Beta's can just slide down. See, AnneMarie, it could be worse!
Re: Find Jimmy Hoffa? [message #4467 is a reply to message #4466] |
Thu, 26 July 2007 10:29 |
colinhester
I did tell the guys if they found any Indian artifacts that they were to just stick them in their pocket. The township was cool about everyting. The plans sailed through in 12 hours. Still haven't heard from the HOA, but I guess they'll just have to live with it....
Re: "False wall" bass trap panels for concrete walls [message #4470 is a reply to message #4465] |
Fri, 27 July 2007 12:38 |
colinhester
I have a copy of CARA somewhere. THe basement is going to be very open floor plan. THe HT / music "room" will be centered in the basement, with 2 stud walls and the other two sides open. I'll try to post a floor plan, if I can find some good (free) software......C
