Home » Sponsored » Pi Speakers » 2Pi Tower dampening
Re: 2Pi Tower dampening [message #44188 is a reply to message #44185] Thu, 18 March 2004 16:08 Go to previous messageGo to next message
Sure can't hurt to try. The insulation is inexpensive and easy to install.
Increase virtual size? [message #44192 is a reply to message #44184] Fri, 19 March 2004 05:57 Go to previous messageGo to next message
Dean Kukral is currently offline  Dean Kukral
It is counter-intuitive that adding too much insulation will increase the virtual size of the cabinet, rather than decrease it.
Would you please explain what is going on?
My understanding is that the insulation is there to minimize the possibility of standing waves. Somehow, I guess, the waves get damped by the insulation; random phase shifts, if you will. Is this correct?
TIA.
Re: Increase virtual size? [message #44194 is a reply to message #44192] Fri, 19 March 2004 11:04 Go to previous messageGo to next message
The addition of the insulation acts as a resistance and also changes the speed of sound in the areas it occupies. So this has the same effect as if the box were made larger.
Re: 2Pi Tower dampening [message #44199 is a reply to message #44188] Fri, 19 March 2004 19:24 Go to previous messageGo to next message
wasteh202 is currently offline  wasteh202
OK... I will do the math
hahahahahah
Depends on material? [message #44202 is a reply to message #44194] Sat, 20 March 2004 09:15 Go to previous messageGo to next message
But Wayne, doesn't this depend on the material used for damping? I read that fibreglass insultation has the effect of increasing effective volume, but other types of foam takes up volume.
Gar.
Re: Depends on material? [message #44217 is a reply to message #44202] Sat, 20 March 2004 22:08 Go to previous messageGo to next message
I've read that too. But my experience has been to always use R11/R13, so all my stuff goes up in virtual volume when you add insulation.
Re: 2Pi Tower dampening [message #44218 is a reply to message #44199] Sat, 20 March 2004 22:10 Go to previous messageGo to next message
Re: 2Pi Tower dampening [message #44237 is a reply to message #44176] Thu, 25 March 2004 06:35 Go to previous messageGo to next message
ports is currently offline  ports
Hi there...I was wondering exactly what is this "DYNAMAT XTREME" stuff -how does it work,where do you get it,how much is it ?Any info would be appreciated.
thanx...ports.
Re: 2Pi Tower dampening [message #44240 is a reply to message #44237] Thu, 25 March 2004 17:29 Go to previous message
Dynamat Xtreme is made for car stereo systems to dampen the metal in the car. It's a constrained layer product, with some type of polymer and a layer of aluminum over it. I've got mine at Pep Boys, in the car stereo section. I get a pack with 2 10"x10" squares for about $20. There is a regular Dynamat that's more of an asphalt, I wouldn't use that. There's a website for it with more info. Also, if you have a CD player that's doesn't have a tank for a case, it helps tremendously in there. Really cleans up the sound a lot.
Previous Topic: Son&Image
Next Topic: Measuring Yorkville TX8 cabs
Current Time: Tue May 07 12:34:37 CDT 2024
