Home » Sponsored » Pi Speakers » Who's on top?
Who's on top? [message #43918] Wed, 11 February 2004 19:28 Go to next message
Is there a reason why HF drivers are almost alway placed on top of the LF drivers? Why can't it go the other way?
Re: Who's on top? [message #43922 is a reply to message #43918] Wed, 11 February 2004 22:28 Go to previous messageGo to next message
Frequencies generated by the tweeter are more readily absorbed by stuff like carpet fibers, so you don't really want the tweeter down by the floor. Plus, the higher frequencies tend to travel more line of sight, so it's nice to have 'em at ear level. But if the speakers are installed high off the ground, perhaps mounted on the walls or high on bookshelves, it doesn't matter if you have the tweeter on the bottom. If they're high enough, it would even be preferable for the same reason that floorstanders should probably have the tweeter on top. Keep 'em close to ear level.
I've been at clubs . . . [message #43925 is a reply to message #43918] Thu, 12 February 2004 11:54 Go to previous message
Tightwad is currently offline  Tightwad
. . . where cabinets are hung from the ceiling, angled downwards, with HF horns at the bottom (i.e. "upside-down").
Presumably for the same reason floor-mounted have the horns on the top.
Previous Topic: Recommendation on Horn Flare for 4 Pi
Next Topic: Midrange+ HF positions,phase and goings-on *Q*
Current Time: Thu May 09 21:32:43 CDT 2024
