Do the 4 Pi stage series need stands? [message #41709] |
Thu, 26 June 2003 18:20 |
Russellc
Messages: 397 Registered: May 2009
Illuminati (1st Degree) |
Wayne, I noticed that this version is only 26 inches high, does it require any sort of stand, or is it designed to sit on the floor? Thanks in advance, Russellc
Re: Do the 4 Pi stage series need stands? [message #41712 is a reply to message #41709] |
Thu, 26 June 2003 19:20 |
Bill Martinelli
Messages: 677 Registered: May 2009
I'm going to jump in with my opinion. In my house I like the 4 pi pro/stage angled back a little or on a stand. At Replay's house they sound fantastic sitting on the floor. So what I really mean is they sound great either way. I think Wayne has some technical reasons they could be better one way or the other. Bill
Re: Do the 4 Pi stage series need stands? [message #41720 is a reply to message #41712] |
Fri, 27 June 2003 11:43 |
Russellc
Thanks for the reply Bill, it is really a tribute to the four Pi that one as horn savey as you are uses them, they must be a fine speaker, i am about to make a plan request! This 4 Pi, The 7pi and the 10 pi all can use the same driver, so I plan on building all three, or at least the 4 and 7 Pi. The ten is really interesting, but not a whole lot smaller than the A7s I am currently using. Thanks for the input, Russellc
Re: 4 Pi stage series placement [message #41722 is a reply to message #41721] |
Fri, 27 June 2003 16:38 |
Messages: 18688 Registered: January 2001
Don't raise four π loudspeakers more than a foot off the ground unless you're using them with subs. It's best to leave them within a few inches from the floor, angled back if desired.If you're using subs, you can put the main four π speakers up a little higher. You'll still want to make sure the floor bounce notch is within the subwoofer's bandwidth, so it will sum with the mains and smooth out the notch. To make best use of subs, you should carefully consider placement of the mains and the subs so the summing of each together forms the smoothest overall response. Also relevant is the bandwidth of the subs, because the can smooth the floor bounce notch from elevated mains only if the frequency of the notch is within the passband of the subs. In general, the closer the subs are to the mains, the higher in frequency they can be run. There are competing proiorities though, because best room mode averaging is provided by distributed subwoofers. You want to position the subs where they smooth room modes best, i.e. constructive nodes from one bass sound source should lie where destructive nodes from another bass sound source falls. So as you can see, there are a few variables to juggle when deciding the best positions and subwoofer bandwidth.
Re: You've got mail! [message #41741 is a reply to message #41727] |
Sun, 29 June 2003 06:35 |
Russellc
Thanks Wayne, I received your e-mail, I had forgotten about the hot mail problem. I have Emailed you an alternative address: cathouse7@sbcglobal.net. Sorry about that! Thanks Wayne, Russellc
