2x10 cabinet size [message #41222] |
Sun, 04 May 2003 20:11 |
little.h
Messages: 3 Registered: May 2009
Esquire |
I'm looking for some help with sizing a 2x10 cabinet loaded with Eminence Alpha 10's. The woodworking will be no problem, but I'm rather confused with all the different software available to determine the cabinet and port sizes. If someone could pount me in the direction of the simplest program for a novice I would appreciate it. Thanks! Stephen
Helmholtz formula [message #41232 is a reply to message #41231] |
Mon, 05 May 2003 22:39 |
Messages: 18695 Registered: January 2001
The Helmholtz frequency is determined by the following formulas:So as you can see from the formulas, if you change the cabinet volume (Ve) and still want the resonant frequency to stay the same, you'll need to change port dimensions.
