Home » Sponsored » Pi Speakers » delta 12LF/KSN 1038 experiment a success!
delta 12LF/KSN 1038 experiment a success! [message #38646] Fri, 11 October 2002 21:28 Go to next message
bqc is currently offline  bqc
I was not sure whether the Delta 12LF would go high enough to be
used with the KSN 1038 tweeter using no cross over. Well I bought the
parts and put them in a pair of floor monitors boxes. The sound is
amazing. I like it almost better than the 2pi studio. There seems to
be less of a 'shout' in the midrange. A look in the Eminence sensitivity
charts gives the explanation. The Delta 12LF rolls off sooner
than the Alpha 10 so it integrates with the KSN1038 much better
since there is almost no overlapping of frequency response. I was
afraid that there would be a hole in the response at around 4k, but
there does not seem to be any. The floor monitor is only a 1 cubic
foot box, so the bass suffered, but not that much. In room response
starts to roll off around 70Hz. These will have excellent bass if
the box is the size of the Theater 3pi or about 3 cubic feet.
The KSN 1038 high end is not as good as the PSD2002 so these cannot
match the Theater 3pi but for $160 a pair (not counting the wood)
since I already have the boxes, the price/performance ratio is
excellent.
Thanks Wayne [message #38647 is a reply to message #38646] Fri, 11 October 2002 21:32 Go to previous messageGo to next message
By the way thanks Wayne for your help. It gave me the confidence
to go ahead with the experiment
Congratulations! [message #38650 is a reply to message #38647] Sat, 12 October 2002 13:23 Go to previous message
Congratulations! Sounds interesting, and I'm glad you're having fun.
About your two π's, have you installed the 0.5mH coil on your Alpha 10's? New (silver label) model woofers need them, and they are really improved by the use of this coil. Also, have you tried the new Tower two's?
I think you'll like those two options as well.
Previous Topic: Lost my 2pi plans in PC crash
Next Topic: pi 2 tower and crossover plan please
Current Time: Fri May 24 16:46:53 CDT 2024
