Home » Sponsored » Pi Speakers » "moonshiner's" black hardware
"moonshiner's" black hardware [message #35301] Mon, 04 March 2002 06:36 Go to next message
not wanting to hassle with mail ordering 12 black pan head 10-32 screws...and there was that perforated steel bottom cover from who knows what. inserted all the screws though the holes, and painted all 12 silver heads in about 0.73 seconds. Only using steel until I can find some brass 10-32 pan heads locally.
regarding 1/4-20 size fasteners recently mentioned...t-nuts for them require a larger pilot hole...less meat around the tnut...jbl uses 8 size 10-32's for woofer mounting...6 of those should suffice for holding the smaller horn flares like the H-290 as long as an appropriate pan head or washer is used. Sam
Re: "moonshiner's" black hardware [message #35302 is a reply to message #35301] Mon, 04 March 2002 08:10 Go to previous message
The screws I used were 1.25" long #8's I think... They had unusually large heads on them, something like 1/4" or 3/8" in diameter. They worked fine.
Adam
Previous Topic: JBL flat frame loudspeakers
Next Topic: Midwest Audiofest!
Current Time: Mon May 13 13:22:32 CDT 2024
