Home » Sponsored » Pi Speakers » Budget Woes and 15" Woofer
Budget Woes and 15" Woofer [message #34593] Sun, 30 December 2001 06:00 Go to next message
craigha@attbi.com is currently offline  craigha@attbi.com
Here's my situation. I'm a software engineer between paying
gigs, so I've got some time but no money. I'd like to pick
a Pi Speaker project and start working on the cabinet - and
get the components later. Going over the archives I have come
up with 2 component options.
1) Eminence Delta 15, Eminence PSD2002
or
2) JBL 2226, Eminence PSD2002
The 2226 is an option assuming I can get a used one at a good
price. I'll decide between bass reflex and folded horn later,
but the smaller Professional 4 is more practical in my house.
Some other background.
My current amps are an HHScott 299B (rated 22wpc) and an
entry level Teac AG-380 receiver. I plan to build a scratch
push-pull EL34 tube amp to mate with the Pi speaker later.
I listen to all kinds of music. My wife is a church organist
and I collect pipe organ CDs and LPs.
What do you think.
What price range can I find a used JBL 2226?
How does the sound quality of the JBL 2226 and Delta 15 compare?
Should I consider other PI speaker?
Thanks. Wayne and this forum are a great inspiration.
Re: Budget Woes and 15" Woofer [message #34595 is a reply to message #34593] Sun, 30 December 2001 08:25 Go to previous messageGo to next message
Charlie G is currently offline  Charlie G
I've been looking for 2226's for awhile for some Pro 4 Pi's. I haven't been able to find them for less than $200 each. If they can be had for less, it'll probably be in an auction/sale/one-time thing.
I don't know how the JBL2226 & Delta 15 compare, as I've never heard either, but take a look on the price page at the dimensions. The Delta needs a much larger box.
I was on the fence between the 2226 & Delta, but given the size of the boxes, I pretty much have to go with the 2226 now. The box for the Delta's is just too big.
Charlie
Smaller box, better sound, $200 [message #34597 is a reply to message #34595] Sun, 30 December 2001 08:34 Go to previous messageGo to next message
If a used good condition 2226 can be found for $200
it is very tempting.
You problems are solved! [message #34598 is a reply to message #34593] Sun, 30 December 2001 11:01 Go to previous messageGo to next message
Robert Hamel is currently offline  Robert Hamel
Hello Craig
Take a look at the JBL Tent Sale. You can get a pair of 16 ohm 2226's for $220 delivered in the 4648 box. Or you can do what I did and order 2 3677 Thearter Systems for $120 each. You get a pair of 2035 woofers which if you run them in a box program are very similar with the 2226. They also have a very flat impedance curve if you look at the 4638 data sheet. The point is you get the pair woofers and 2416 compresion drivers for what you are willing to spend on a single driver.
http://www.jblpro.com/Tent_Sale
Well good luck
Professional four π vs. Theater four π speakers [message #34599 is a reply to message #34597] Sun, 30 December 2001 11:20 Go to previous messageGo to next message
I'd have to agree. The Delta 15 used in the Theater Series four π is nice, but it doesn't compare to the JBL 2226 used in the Professional Series four π loudspeaker. The JBL woofer is about $250 more, but if you can spare the change, it's definitely worth it.
Re: Budget Woes and 15" Woofer [message #34600 is a reply to message #34593] Sun, 30 December 2001 15:20 Go to previous messageGo to next message
Jammin Jersey, worst kept secret on the net for used pro speakers.
I will have, probably, a pair of either 2035H or 2226J for sale cheap, depending on what I build with the junk I bought at the tent sale.
You really should sink $232 into a pair of the 3677 and be in the catbird seat yourself. Put the drivers into a 9 cu ft box and dig some French organ music.$232 including freight for almost $1000 worth of speaks!
Sell the organ.
Tent Sale 3677S-B ? [message #34602 is a reply to message #34598] Sun, 30 December 2001 16:20 Go to previous messageGo to next message
Looking for the 3677 at the tent sale I found this.
Is this a 3677 cinema loudspeaker?
http://www.jblpro.com/Tent_Sale/sale_items.htm
3677S-B S/M 3677S (M115 W/O NETWORK) 1 163.61
From the 3677 PDF:
The JBL 3677 cinema loudspeaker
The high-frequency section consists
of the JBL 2416-1 pure titanium com-pression
driver and 2373 Flat-Front Bi-Radial horn.
The low frequency driver is the
JBL 2035H, which provides an
exceptional match for system power
handling and frequency response in
the crossover region.
Correct entry must be 3677S [message #34603 is a reply to message #34598] Sun, 30 December 2001 16:44 Go to previous messageGo to next message
This is The 3677 speaker.
Sale line:
3677S S/M 3677S (M115 W/O NETWORK) PDF 115 118.51
Thanks.
Thats them a good deal! [message #34604 is a reply to message #34602] Sun, 30 December 2001 17:35 Go to previous messageGo to next message
If you don't like the woofers you still have the compression drivers and if you like the woofers and don't need the 2416's you can part them out. You can't lose!!
Correction they are just before the new stuff!! [message #34605 is a reply to message #34604] Sun, 30 December 2001 17:37 Go to previous message
Sorry I read your post too quick. Same stuff lower down the list.
Previous Topic: Parts for Theater 4 Pi?
Next Topic: JBLPro e-sale 3677S is tempting
Current Time: Mon May 13 21:03:36 CDT 2024
