Ordered a 10" woofer from P.E. that was supposedly made for and refused by Klipsch. Great big shielded aluminum thing, $95. Also the 120 watt plate amp for an astounding $79! It seems as though most of the P.E. verbiage concerns closed boxes, as well as some DIY sites. It seems the closed boxplots are a little deeper than vented. Is bass QUALITY better with vented? This particular woof is: FS 32.8 Vas 3.24 QMS 7.95 QES .21 QTS .20 XMAX .18" Boxplot likes a 3.5 cu.ft. vented, way smaller closed. So what's better?
Wayne Parham Messages: 18678 Registered: January 2001
Most people use a rule of thumb that essentially says high Qts, low Fts speakers go in sealed boxes and low Qts, high Fts speakers go in ported boxes. I prefer to use bass reflex, and the reasons why are discussed in the threads called "Acoustic Suspension vs. Bass Reflex" and "Pi Alignments compared with B4, C4 and QB3."
Several graphs are shown below that describe various common tuning methods along with a couple examples of mal-aligned systems. I was asked to do this a few days ago, and with Till's most recent post, it seemed an opportune time to illustrate the response that can be expected from various systems.
Each of these graphs were prepared using a woofer motor having the following characteristics:
Note that I use the term "optimal" in a way that can be interpreted to mean "critically damped." In other words, when I describe an "optimally tuned cabinet" or one having "optimal size", many would refer to this as being critically damped. There is merit in building systems that are not critically damped for various reasons, and one should not misinterpret the term "not optimal" as excessively derogatory. However, "critically damped" motor cabinets provide the best performance, so the term "optimal" is accurate.
