Home » Sponsored » Pi Speakers » mounting bolt size jbl 2226
mounting bolt size jbl 2226 [message #33923] Wed, 26 September 2001 12:52 Go to next message
jazzbo is currently offline  jazzbo
I'm machining the cutouts for the driver for pro pi7's. I have the circle cutout dimensions from the plans, but would also like to install the t-nuts (8) for mounting. Can someone advise me on the hole diameters, or recommended screw size. Has anyone used t-nuts for mounting, or just wood screws?
Thanks
Re: mounting bolt size jbl 2226 [message #33929 is a reply to message #33923] Wed, 26 September 2001 17:23 Go to previous message
If you purchased new 2226's, they'll come with screws and T-nuts included in the box. The thread pitch is 10-32. You'll need to drill 1/4" holes on the baffle to install them.
Previous Topic: Crossover document - Second draft
Next Topic: His Eminence is here (extremely long)
Current Time: Sun May 26 02:28:43 CDT 2024
