Home » Audio » Group Build » Smith Horn Group Build - Please Complete Survey
Smith Horn Group Build - Please Complete Survey [message #31966] Fri, 15 September 2006 10:06 Go to next message
There seems to be some good interest in a Smith Horn group build project. If you are interested, please complete the survey below to determine the level and type of "prep work" we're looking for.
Throat Size:
- 1"
- 1.5"
- 2"
Pre-fab Components:
- Vanes
- Throat Plate
- Body
Vane Pre-fab:
(What type of joinery are you looking for? A mortise joint will require an increase in the vane to account for the tenons. Dowel joints can use the same vanes as butt-joints)
- Flat butt joint
- Mortise joint
Throat Adaptor:
- Straight bore
- Circular to rectangular transition
Pre-fab Material:
- MDF
- hardwood
Please add any other questions you think I may have missed.
gar.
Re: Smith Horn Group Build - Please Complete Survey [message #31967 is a reply to message #31966] Fri, 15 September 2006 10:09 Go to previous messageGo to next message
Here's my response:
Throat Size:
- 1"
Pre-fab Components:
- Vanes
Vane Pre-fab:
- Flat butt joint
Throat Adaptor:
N/A
Pre-fab Material:
- hardwood
My survey [message #31968 is a reply to message #31966] Fri, 15 September 2006 10:49 Go to previous messageGo to next message
Throat Size:
- 1"
Pre-fab Components:
- Vanes
- Throat Plate
Vane Pre-fab:
- Flat butt joint
Throat Adaptor:
- Straight bore
Pre-fab Material: either
ditto (nt) [message #31969 is a reply to message #31968] Fri, 15 September 2006 11:37 Go to previous messageGo to next message
Re: Smith Horn Group Build - Please Complete Survey [message #31970 is a reply to message #31966] Fri, 15 September 2006 12:33 Go to previous messageGo to next message
Here's mine:
1"
Vane
Throat Plate
Body
Mortise/ either one is fine but I like the joint integrity of the mortise and I don't see why it would be a lot more money so why not?
I would like to use one of my Altec drivers so I would assume that means rectangle to circle? If not then eithor one will do.
Hardwood; I guess plywood is out of the question then? Baltic Birch?
Looks good so far.
Thanks for doing this survey Garman.
Re: Smith Horn Group Build - Please Complete Survey [message #31971 is a reply to message #31966] Fri, 15 September 2006 14:33 Go to previous messageGo to next message
Hey-Hey!!!,
I am not sure what you mean by 'vanes'.
anyway...
1.375 throat.
Conical section, 19" axial length
8 petals to approximate the cone, 13 mm, 11-ply birch?
35-degree included angle/flare, maybe 40
Mating to two-bolt old RCA compression driver. Throat terminated in the mounting plate, perhaps 1/4" copper? no special throat section.
cheers,
Douglas
Re: Smith Horn Group Build - Please Complete Survey [message #31972 is a reply to message #31971] Fri, 15 September 2006 15:54 Go to previous messageGo to next message
The vanes are the petals inside the horn to create the flare.
Re: Smith Horn Group Build - Please Complete Survey [message #31973 is a reply to message #31972] Fri, 15 September 2006 16:06 Go to previous messageGo to next message
Oh, got you...:)
Yes, 8 vanes. Probably 40-degrees included, or at least that is what my notes say. Now to get the good plywood.
The issue I have is that it requires a 22.5 degree miter. With a serious tool shortage, this isn't easy to step around. The back plate/mount is quite easy by comparison...:)
cheers,
Douglas
Re: I'll listen to Steves. Enough unfinished projects. nt [message #31974 is a reply to message #31968] Fri, 15 September 2006 16:57 Go to previous messageGo to next message
Sounds good to me! (nt) [message #31975 is a reply to message #31974] Fri, 15 September 2006 18:39 Go to previous messageGo to previous message
nt
Previous Topic: ART Array Kits
Next Topic: ART Array Kits - Anyone??
Current Time: Sat May 11 08:29:45 CDT 2024
