Home » Audio » Group Build » DRD 300b set amp
DRD 300b set amp [message #31079] Sun, 01 May 2005 20:38 Go to next message
I am geting ready to start my DRD amp. If anyone is looking for a good SET amp, or a less ambitious project then what "T" is Proposing, you are welcome to come along. We will end up with something much like what Ron Welborne is offering. \
The first step will be haveing a power transformer made up. I am thinking Taps for 600 and 700vac
for a look at the citcuit look here
Re: DRD 300b set amp [message #31080 is a reply to message #31079] Sun, 01 May 2005 23:15 Go to previous messageGo to next message
Oh, now that's pretty cool too. I seem to recall discussing this amp several months ago, as it was described in an article in VTV #14. Sounds like a good deal; I may join you on this one.
Re: DRD 300b set amp [message #31084 is a reply to message #31079] Mon, 02 May 2005 06:32 Go to previous messageGo to next message
Not tried it in the real world, but it`s the pleasure to SPICE it and look at the clever & tricky way this amp is made. Anode current for the 300B is ~70mA, and Ia for the paralelled input tubes ~14mA. Direct coupling, bias voltage for the 300B "made" partly from Rk, partly from DC voltage drop across Rw (about 1k4) of the choke... Tricky, but simple enough!
The only concern is high B+=700V and even higher HV PT winding- 1110 Vct...
Many people already built this or similar "Monkey/DRD" amp, I found lot of info in the DIY archives... Good luck, and post about the building it, photos, etc
Re: DRD 300b set amp [message #31085 is a reply to message #31079] Wed, 04 May 2005 09:20 Go to previous messageGo to next message
paba is currently offline  paba
on the same site there is this one too.
www.electra-print.com/drd6an4.html
Re: DRD 300b set amp [message #31121 is a reply to message #31079] Fri, 27 May 2005 13:21 Go to previous message
DaveG is currently offline  DaveG
This looks like an interesting build. Count me in for the power transformer.
Previous Topic: Little amp
Next Topic: Say Douglas/813
Current Time: Sun Apr 28 16:54:19 CDT 2024
