Home » Audio » Group Build » Location of Selector Switch in Preamp
Location of Selector Switch in Preamp [message #30875] Mon, 07 March 2005 14:22 Go to next message
This question is unrelated to Guinevere, but is about DIY preamps. I've seen a lot of preamps that place the selector switch in the back of the chassis. What benefit would this have? Whether selection happens at the rear or at the front, the signal still has to travel from back to front to the volume knob. I can see that it cleans up wiring a bit, in that only one set of wires has to travel back to front, instead of 2, 3, or 4 sets.
Gar.
Re: Location of Selector Switch in Preamp [message #30877 is a reply to message #30875] Mon, 07 March 2005 16:06 Go to previous message
Hey-Hey!!!,
being a one-source builder sort of simplifies tha one for me...
If you put the switch right next to the inputs, you can run a single wire to the volume knob. If this changes the amount of noise pick up, I am not sure.
I'd consider the neatness and simpler is probably the better way to go. Short wire to teh switch, single to the volume control. That's my opinion anyway.
regards,
Douglas
Previous Topic: the Amp
Next Topic: Guinevere wired and ready.
Current Time: Sun Apr 28 07:23:09 CDT 2024
